Question about Garden
MM675 electric mower will not start. Is this a circuit breaker issue?
  • owen5188 Jul 17, 2010
    MM675 electric mower will not start. Is this a fuse issue? Where is this fuse in the mower located and how do I reset it? Someone at home depot told me that there is a simple button to push. Can someone provide a diagram/manual showing how to troubleshoot this?
  • 2,272 Answers
Yes there is a switch.Its called "dead man switch" Inside the black plastic housing that the "dead man" switch comes out of is a plunger switch that is pushed down by the "dead man" switch when it is pulled back. The plunger switch has four wires connected to it and is the "real" safety switch. If that plunger doesn't go down the circuit is not complete and the mower doesn't go. --------- you cut the wires to the plunger switch and connect them directly to each other. The plunger switch is built by INTAK, but searching for the part number directly on the Internet doesn't work very well. But it turns out other people have had problems with the plunger switch in Black & Decker electric mowers. Following that lead the replacement switches can be bought from DeWalt (which apparently owns Black & Decker). you can buy this switches for $12. the on/off switch built into the handle. Basically it is a "dead man" switch which only allows the mower to run while you hold the spring backed handle in place. Taking your hands off the handle immediately cuts power to the mower. This can be a lifesaver (literally) if you notice you have just run over something like a rock or piece of glass which you missed in the yard before you started mowing. check out. thanks.
Posted on Jul 18, 2010
  • owen5188 Jul 19, 2010
    I tried to mow one last time. It started out slowly, then got to full engine power. It mowed OK for a few minutes, then I released the bar to turn it off. Instead of the usual, immediate shut-off, that is, the blade stops turning and the engine is quiet, the engine slowly wound down and eventually stopped. I could not restart the engine by pulling on the bar. This sounds different from what you described, which a dead-man's switch function: complete on or off. Is there something else to explain why the mower slowly died, then could not be restarted? Is there some other reset button? I couldn't find any under the black plastic housing. Do I need to remove the orange deck to access something? Wish I had a schematic of the entire machine.
    Hope you can help me out further.
    Guru:
  • 632 Answers
This could a fuse has blown either on the plug socket or within the mower
Posted on Jul 17, 2010
    how do i check or reset fuse? where is fuse located?
  • Simon Swales
    Simon Swales Jul 19, 2010
    At the end of the cable you plug into your mains electric socket The head you can remove by removing the screws and replacing the fuse inside it.
Lawn mower batter charger blows circuit breaker
I'd try plugging it into another outlet first, then try turning off any other appliances that might be on that same circuit. If it continues to trip the breaker, I'd take it to the small engine shop.
hope this helps
Apr 19, 2014 | Toro Garden
I have an earthwise 12 amp electric lawnmower that trip the circuit breaker and now will not start at all. Any suggestions on what might be wrong and how I could fix it
If the circuit breaker trips there are three possible reasons
1. the motor is being overloaded - clean underneath ( as recommended above); or if the grass is too wet or too long or both you may need to handcut; or the motor bearings need lubricating (same problem as me-how?)
2. There is an electrical fault - check the plug and cord (as above) or get an electrician to check the motor and connections; or the carbon brushes to the motor need replacing
3. You have a faulty circuit breaker! - borrow and test with a replacement
Apr 11, 2012 | Electric Lawn Mower
My lawn mower just stopped working. I was mowing along and it just stopped. It is an electric Black and decker. I was mowing regular grass, nothing complex. It was working fine before that. It is very new...
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Nov 29, 2017 | Electric Lawn Mower
Jcb electric mower just makes clicking noise wont start
some of these mowers have reset buttons on the motor---it works like a circuit breaker---access the motor housing to check for a button
May 10, 2010 | Acer Lawn Mower
Up and down Lawn Mower RPMs
Spounds like a problem with the governor. There should be a spring or something tied to your governor. The governor adjusts your air fuel mixture according to the load. Look closely at all points of connection...Lee
Sep 13, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black&Decker MM675 lawn mower height lever would not stay
I would look in my owners manual and get the part number for the height lever and order a new one. You could also try and wire the height lever so it can not move. I am not sure how it engages but you could may be try and bend the lever so it is tight and won't move. Just a couple of ideas.
Good luck
Aug 31, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric lawn mower repeatedly trips house circuit breaker
The breaker is tripping because there is a short in the mower electrical circuit -- most likely in the motor winding -- it overheated.
If you have a multimeter measure the resistance (ohms) of the motor winding by putting the meter probes on the two flat prongs of the power cord with the mower switch on. If you get near zero ohms, the winding is shorted -- motor "burned up".
Using the multimeter again, check for continuity between the round ground pin on the power cord and each of the two flat prongs. If you get continuity on either of these, there is a short to the mower chassis. This can probably be corrected without much expense.
My bet is on the motor winding being shorted.
Charlie
Aug 20, 2009 | Craftsman Garden
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
My electric lawn mower starts briefly and then trips the circuit
check cord from plug to the electric motor.if it has a reset or breaker check for damage. if no obvious damage problem is electric motor.may be cheaper to buy new 1
May 06, 2009 | Electric Lawn Mower
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
