Question about Dell Dimension 2350 PC Desktop
Dell dimension 2350 keeps shutting down
My computer shuts down by itself when I turn the computer on. I tried to go to CMOS setup and waited to see if it will shut down to determine if it is microsoft issue, apparently it did shut down which means it is not microsoft problem. I opened the computer and checked the fan and it is working. I removed RAM slots and tried rebooting same problem. I noticed one of the brackets of the heat sink is broken but the heat sink is on top of the cpu with one bracket, I don't think this will cause the problem as far as I know. The only other issue I think could be the power supply or the cpu but it is costly buying those just assuming they could be the problem. I have some important data inside the computer which I want but can't reach them because no backup.
Is there anybody with a solution?
I appreciate your help
  • Dell Master
  • 5,568 Answers
Almost certainly the power supply; they have a dozen different ways to fail and mostly due to a 5 cent component that should have been a 7 cent part.
I highly recommend not replacing it with another (original) 200 watt supply; running a supply too close to its ratings causes it to work hard all the time.
The supply on eBay linked below is 480 watts which is overkill but it is the cheapest on the 'Buy it now' listing and comes to $21 with shipping-
Dell replacement PS
If you have never done this before and are apprehensive, take a few photos of plug placement in case you get confused.
Good luck-
Posted on Jul 18, 2010
    Scholar:
  • 70 Answers
It is quite clear from your description that the issue is with the heat sink. Since the heat sink is not seated properly on the cpu, it is getting heated and thus causing the system to turn off. CPU is a very sensitive part of the computer, if it is gone bad you will not be able to see anything on the screen. You simply need to re-seat the heat sink properly and that would resolve your issue. You can trust me. If you can manage to replace the heat sink it would be great or else if you want to confirm what I said you can just try to remove the heat sink and try to do a temporary fix to one of the broken bracket.
Posted on Jul 17, 2010
Dimension 4600 dvd drive keeps opening
Try this first - open up the BIOS part of the system. To do this, shut the computer off; wait at least 10 seconds; turn the computer back on and then press F2 when the Dell logo appears. Press continually until the message Entering Setup appears. In the Boot Order section, remove the CD/DVD drive from the boot order by clicking on Disable from the drop-down menu. If this doesn't fix it, please resubmit your question
Feb 19, 2015 | Dell Dimension 4600 PC Desktop
Dimension 2350, on stARTUP ONLY
Remove the power cord, remove the case and look inside the computer at the capacitors. See if any of them are busted or leaking corrosion. The capacitors look like little battery towers but they are not as tall as AA or AAA batteries.
May 02, 2012 | Dell Dimension 2350 PC Desktop
How can i go to bios setup
Straight from the Dell website:
  1. Turn on (or restart) your computer.
  2. When "F2 = Setup, F12 = Boot Menu" appears in the upper-right corner of the screen, press .
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then shut down your computer and try again.
I hope this answers your question!
Apr 15, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
Booting issues...Connected to RAM?
Most likely cause is that your new RAM is not compatible with your system. Check the user manual to determine the type and size of RAM that you can use in this machine.
Mar 06, 2010 | Dell Dimension 2350 PC Desktop
The dell dimentions 2350
Ensure that both the case fan and CPU fan are dust free and spinning. I think it could be overheating and then shutting itself off to prevent damage
Feb 01, 2010 | Dell Dimension 2350 PC Desktop
No post screen, cant access cmos settings. but windows starts as usual just a blank screen til then?
Its possible that your cmos settings were changed prior to this problem so as not to display cmos settings options at boot up. Have you tried resetting your cmos settings to fix the problem? You can do this by a jumper which is usually found on the mother board named "clr cmos" (clear cmos).
Let me know if this is of help or not.
Regards,
Graemevm
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension 2350 PC Desktop Logo
234 people viewed this question
Alun Cox
