Question about Canon MV650i Mini DV Digital Camcorder
Power save feature
I want to use my camera for shooting a stop-motion movie. I connect it to the main power and to my computer thru the firewire cable. All works fine, but after a rather brief period of inactivity my camera goes asleep and I have to switch off/on the camera. Is there a possibility to override this?
Problem solved! Removed the cassette which disables sleep time for camera.
Posted on May 27, 2008
  • 3 Answers
ارغب في برنامج لتعريف كاميرا نوع كانون mv650i
When i was taking picture the lens of my camera ( sony dsc-w120) become blurd. why'?
The cameras capacity to capture motion pictures is disimpressionful. Usually cameras have feature functionalities either as still picture shoot or motion video recorder devices. Cameras may have any once of the mentioned features or both as complementary for videographic requriements. Inspecte the camera for capacity to capture motion picturee. Usually, the lense capacity with pixel capacities are indication of extensive capabilities. An impressionful camera producign disintergral result requries adjusting the lense or pixles buttons prior to photo shut. Also, cameras that least have the pixel capacity requires photo shoots at still motion or at calm climate least onbracting activities. Capture pictures at areas that least have movement caused by human interfernce or windy or suny blurs. Also, capture pictures maybe retored of blurry filming from computer photo video editor programs. Capture the picture or videos to be loaaded on to a computer that allows editting to achieve desired interfaces.
Feb 07, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
First, you need to have an SD card installed; the 8025 will not record video to internal memory. Second, be aware that the 8025 will not record any sound to accompany the video.
Press the Home button to bring up the main menu. Select Movie Mode (movie camera icon). Press the shutter button to begin shooting. Press the shutter button to stop shooting and save the file.
If you need a manual, you can download one from the manufacturer's web site at
May 09, 2010 | Vivitar ViviCam 8025 Digital Camera
PV-DV103 will not connect to pc via Firewire - Windows Movie makr
ur COMP. graphic is low. ur camera need capturing card on PC u can edit ur pic in movie maker
Mar 17, 2009 | Panasonic PV-DV103 Mini DV Digital...
Connecting the Canon FS 100 to my iMac
jhobby2000 buy a usb 2.0 specially for SD or SDHC chip
Dec 31, 2008 | Canon FS100 Digital Camera
Unable to use firewire Sony handycam DCR-HC 54E (mini DV)
Anyone try this on Windows XP? Apparently firewire doesn't work with Vista.
Dec 10, 2008 | Video Cameras
I need drivers for JVC GR-Dv500 camera
GR-DV500 is a miniDV vcam w/c must be FIREWIRE**-connected to a pc to upload video thru video capture or video editing* application while vcam is on playback. Before cable** purchase, note: Firewire port of vcam is 4pin...check the firewire port of PC whether 4 or 6 pin.
Normally, the drivers are bundled with your computer OS, such that when the vcam is connected, the vcam is recognized by the video editing programme.
For starters, free Windows Movie Maker* (XP-wmm2 & Vista-wmm6) provides simple & easy way to learn the ropes < click help for details>. Upgrade to other video editing app accdg. to need & skill level
Video Editing Process
>>> open wmm- start/all programs/wmm->TASK pane
..Step 1. Capture/Import video files (+pics, music) to be edited
..Step 2. Edit- drag/drop files->timeline & enhance w/effects, transition, music & titles
..Step 3. Finish (render)- save Movie file, also save Project* file
..Step 4. Share-burn to CD (to DvD thru a DvD authoring app)
Jul 11, 2008 | Cameras
PC Wont register Camera is connected
If it is a cam corder, a lot of them only work for stills once hooked up to the PC (via USB). Are you certain the cam be used via a computer.
If the camcorder contains both USB and IEE1394/firewire and your computer has both USB and firewire, then sometimes the USb interface is set to stills only and the firewire interface is set to motion only.
Which make/model?
Feb 27, 2008 | Cameras
Can't upload videos to computer
The JVC cameras have a flip-out screen, behind this is a small port to which the camera cable connects, kind of "M" shaped. It may also have a DV port hidden behind a small plastic door somewhere on the camera. The other end of the cable goes to the back of your computer tower. Turn the camera's power switch to "Play" or VCR mode and then connect the cable to the tower. Windows should detect the camera, load it and then offer to capture the footage using Windows Movie Maker. The video imported is saved to your "Videos" folder by default. Under start, go up to your user name at the upper right -- usually your name-- and inside the window that opens look for Videos.
You can then use Windows Movie Maker to capture and edit your movie.
Nov 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Firewire stopped
Though you have checked the firewire card, try the process for your camcorder with a new firewire card.
May 03, 2007 | JVC GR-DVX70EG Mini DV Digital Camcorder
Canon MV650i Mini DV Digital Camcorder Logo
67 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
