Question about Whirlpool GEW9250 Electric Dryer
Dryer drum lamp burnt out. displays now flash. dryer wont start. is there a connection?
  • 1,998 Answers
Connection between your lamp not working might be due to your door switch that is not working test the door switch see i it makes a clicking sound when u depress it if it doesnt make clicking sound theres your problem if it does then your in for some easy testing of rune fuse and to relays one is a hi other is a low allthree of these should be checked or continuity if any of these three pieces do not have continuity then that wouldbe te one that you would replace hope this helps
Posted on Jul 17, 2010
Kenmore electric dryer model 88042 runs but stops short beeping
Based on symptom and details, the control has detected a component failure. Since your model does not have digital display window in order to display a fault code, it will flash the four indicator lights of
Drying, Cool Down, Wrinkle Rid (Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator light will flash the number of times for the second digit.
Take separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light will flash four times indicating the 4. The four indicator lights and the START indicator light
start flashing at the same time. The control will pause for 2 seconds, then repeat the code.
The failure is likely because of a faulty thermistor or because the heater is not working. It could have a broken heating element or a burnt wire connection at the control board. I would begin by accessing the thermistor and disconnecting it. The thermistor can be tested with an Ohm meter. The thermistor should measure approximately 50,000/5K Ohms at room temperature.
The heating element is located behind the drum and it can be disconnected and tested for continuity with an Ohm meter.
NOTE: Disconnect the dryer from the power supply before servicing.
Jun 02, 2018 | Kenmore Dryers
Dryer wont spin
It sounds like your dryer drum drive belt may have broken. Top replace the belt follow the instructions below.
PLease go HERE for a video instructional of thewhole job.
Jan 27, 2012 | GE Dryers
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Lg troom dle 3777w dryer does not turn on!!!
Sounds like you have 110 volts going to the dryer, you need 220 volts for a dryer to operate normally, check for propper voltage at the back of the dryer where the power cord connects to the terminal block, then if all is good there check at the receptacle on the wall that the dryer is plugged into for correct voltage there, look for bad wire connections, or burnt wire connections or obvious signs that don't appear normal, also don't forget to double check your circuit breaker at your homes electric supply panel. Good luck and Merry Christmas!
Dec 25, 2009 | LG DLE3777 Electric Dryer
DRYER RUNS TEMPERARILY WITH WHINNING NOISE THEN SHUTS OFF.
take off front of the dryer the drum will fall out clean drum and replace belt
Feb 10, 2009 | Whirlpool LER5636P Electric Dryer
Control pannel wont cut on and dryer wont start
We are having the same problem. We have the Neptune dryer MDE5500AYZ. The control panel doesn't come on. We know it's getting electricity as the light in the dryer is on. Is there a reset button in the dryer?
May 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
120 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
