Question about Goodman CKL42AR42 Air Conditioner
Where is the fuse box?
I have a g
Goodman ac unit and yesterday it worked just fine. We had a thunderstorm this morning and I am wondering if ithe unit was struck. We have nothing happening! We were trying to find a fuse box before we call a service man. Any clues?
  • 744 Answers
Does the indoor unit run?
It sounds like you're looking in the right place. Check your power panel for a tripped circuit breaker (maybe more than one) or if the home is older, it may have fuses. It's possible that the outdoor disconnect also has fuses but that's not as likely. You can check around the outdoor unit and see if you smell anything burnt.
You can aso turn off the unit at the thermostat, wait a few minutes and see if the unit starts back up, but check the items listed above first.
Posted on Jul 17, 2010
  • 674 Answers
There should be a disconnect outside near the outdoor unit. Check it for a tripped breaker or blown fuse. Look at the circuit board in the outside unit for a small fuse. At the thermostat, take the fan switch from auto to run. This will check the transformer. If the fan runs the transformer is ok. If it doesn't then check the transformer. Let me know what you find and we can go further from there.
I have a goodman furnace that was installer 2 weeks ago. It ran fine until it blew a 3 amp fuse this morning. It works fine as long as I do not have anything plugged into the Com terminal.
c is your common, u only use it if you have ac, humidifier, or u use 24 volts for t- stat, follow the common wire and see what it feeds u do not net it for heat, could be ur ac or humidifier has a short in it
Dec 20, 2015 | Goodman Heating & Cooling
My AC unit just died out of the blue.
Sounds more like a bad breaker possiably not getting power to your unit I would check the breaker first
Jul 21, 2013 | GE "General Electric AEN10AQ 10,000 BTU...
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
Location of overvoltage protection
Go outside to the condensor, its unlikely that the fuses are there unless it is an older unit. Turn off the power and open the power disconnect box. That is one place the fuses or breaker could be.
In the house you should have an electrical panel usually grey in color. Open the service panel as it should be hinged. Most of the time the fuse or breaker is labeled AC Unit andThe rating should be
anywhere between 25amps-60amps.
Jul 20, 2010 | Goodman CKL24AR24 Air Conditioner
Where is fuse located on goodman ckl60-1 ac unit?
I'd be surprised if you had a fuse in either the outside or inside unit. Typically the fuse(s) are mounted in a gray electrical box (on the house) near the outside unit.
You can usually - easily see the fuse box but if you don't just follow the electrical conduit from the outside unit - to the fuse box.
good luck!
Apr 30, 2010 | Goodman CKL60AR60 Air Conditioner
Unit will Not turn on
Hello. There is usually a separate circuit breaker in an electrical box near the outdoor component. Chances are it was turned off at that location for the winter. Joe
Apr 03, 2010 | Goodman CLQ36AR49 Air Conditioner
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
199 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
