Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
No cleaning solution or water will spray out
  • lunchlady_75 Jul 18, 2010
    there is no water or cleaning soulition spraying out I yore everything apart I could and cleaned everything and rechecked putting everything back together right
    thanks Cathy
  • 532 Answers
If no cleansing solution or water will spray out check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Thanks for contacting Fixya.
Posted on Jul 18, 2010
  • 10,865 Answers
Hello.
Possible Cause Remedies
1.
Water tank may be empty. 1. Fill heavy duty bladder with hot tap water.
2. Formula tank may be empty. 2. Fill formula tank with BISSELL Fiber
Cleansing Formula for cleaning.
3. Tank may not be seated completely. 3. Turn power OFF ( O ). Remove and
reseat tank.
4. Pump may have lost prime. 4. Turn power OFF ( O ) and then back
ON ( I ). Wait one minute, then
depress Trigger.
Here is a copy of the owner manual for your use.
http://canada.bissell.com/images/UserGuides/9500_107.pdf
J.
Posted on Jul 17, 2010
LIttle Green Bissell Water goes directly to collection tank, won't spray
Had a problem with mine not spraying, took ot apart and the heater for the solution was plugged with scaling, cleaned it up and works the very best now. As far as clean water going directly into the collection tank, sounds like the little hose may have a break or a leak in the vacuum hose.
Mar 14, 2018 | Bissell Vacuums
Get Bissell little green pro heat to spray?
These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Will not spray water
When this happens you usually have a blockage in the tubing. Old cleaning solution gets dried up and hardens and then blocks the tubes. You need to take the tubing off and clean it all out or untill you find the blockage. Once you get it spraying agin clean the system with hot water and flush it all out. Always spray just water for a while after you use any cleaning solutions and this will keep the tubing cleaned out. Does this help? do you need more assistance let me know.
Nov 19, 2010 | Bissell PowerSteamer Deep Cleaner Plum...
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
On a Royal #CE6600 it will not spray water on rug,
spray opening may need cleaning (small wire may work)
Aug 31, 2009 | Vacuums
Bissell Proheat 9500 won't spray water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ukyr
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner
If water is spraying from the tool hose, then check the heater for a blockage. If the heater port is blocked, then the water can't flow back down to the spray nozzles, which could also be clogged. Most likely a clogged heater, it is in the handle.
May 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
411 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
