Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Lawnmower Model CMM1000 Batterys will not charge.
  • 1 more comment
  • Anonymous Apr 26, 2008
    My CMM1000 black and decker lawn mower won't charge. I've had it plugged in for days and the little green light won't stay on, and the needle keeps pointing to empty. Any help...? I'd really appreciate it!
  • ekulpa Apr 27, 2008
    I've ordered a new battery. A $160.00 value. I can't see anything else that could be the problem. I'll let you know if it works. When it arrives.
  • GaryRe Jun 14, 2008
    I am trying to find new batteries for this same mower - where did you get yours? Did new batteries fix the problem?
All of a sudden mine also acted like it wouldn't take a charge and the needle wouldn't move. The plastic safety key also wouldn't insert smoothly as it used to and I would have to push the start lever before it would drop in. When I checked the charger, it was putting out 24v. When I opened up the lid I noticed that the starter cable was pushing the safety switch incorrectly. If it was moved a bit, the mower would then start. The starter cable is only secured to the handle by tie wraps. So if it gets moved around, it can cause the kill switch to be in the kill position. So now if I have a problem, I just move the cable in or out a bit. Fortunately, this find saved me a trip to the dealer and who knows how much $$$$.
Posted on Oct 15, 2009
  • alvazai Aug 16, 2010
    Thank you so much, Jdnfam. I was about to purchase a new battery pack but I was fortunate to read your post. I just massaged a bit the starter cable and it worked like charm.
    B
How long should it take to charge after i put in new batteries
Posted on Aug 09, 2009
I bought one at a garage sale, same thing would not hold a charge. I phoned black and decker and the circuit boards are faulty. They are trying to claim that the battery makes the board faulty, but the bottom line is they replaced the circuit board for free. Call your local dealer.
Posted on May 26, 2008
Could also be the recharger/transformer; I just replaced mine.
Posted on May 15, 2008
CMM1000 models types 1-4 are being recalled. Check out blackanddecker.com
Unfortunately, I have type 5 and cannot recharge the battery. I used the mower twice.
Posted on May 10, 2008
I have the exact same problem. It did'nt used to happen, but now I've had it plugged in for days and the little green light won't stay on, and the needle keeps pointing to empty. Sorry I can't help you, please let me know if you've solved your problem yet.
Posted on Apr 26, 2008
    Champion:
  • 313 Answers
Need battery.suggest to upgrade unit to cmm1200
Posted on May 31, 2008
Can you reprogram a 24 volt(2-12s) on homelite lawnmower?
no once there memory is gone thats it and i no there are expensiveyou memery train them when you first charg them by making sure you completly discharge the battery once there trained they last a lot longer
May 14, 2013 | Garden
I have minolta DiMage camera and it will not reconize fully charged batteries, it show battery as being 1/2 full and I put new batteries and it still won't reconize. I have cleaned the battery posts, but...
When you said new batteries, did you mean a fully charged battery? If so, it could be that your batteries are nat capable of holding a full charge. Otherwise, my suggestion would be to Call the manufacturer for tips or help.
Apr 10, 2008 | Cameras
I just purchased a Toro e-cycler cordless mower, model # 20360. I tried plugging in the charger to the Ac outlet and the mower receptacle. My understanding is that the charger light is suppossed to be...
It could be that the batterys don't need to be changed and shouldn't be unless fully discharged, if u charge before the batteries are fully discharged u run the risk of damaging the batteries. The problem is sometimes batteries get what is called a memory charge, this means if u use your lawnmower for a short time than charge it and u do this repeatedly the batteries will only discharge for this sort time and will only charge for a sort time. Than if u need it for a big job it will seem that u have only operated it for a little time and u need to plug it in. The only way to fix the batteries is buy new ones, that way they always tell u to always fully discharge before recharging your batteries.
Sep 15, 2011 | Toro Garden
My cmm1000 type 4 lawnmower does not start
Check to see that the starter cable isn't pushed in or out a bit too far and causing the kill switch to engage. It is only held in place by tie wraps and can cause the machine to act as if it can't be charged and/or won't run. Once the cable has been adjusted into the correct position, everything works as expected.
Oct 07, 2009 | Black & Decker 19" Electric Lawnhog...
Black & Decker CMM1000: The mower runs, but has no power
The battery is dying., need to be replaced. price is around $100.00 so be prepared to invest a couple of bucks. I believe there is an update "RECALL" on this units so you better call their customer service.
Sep 20, 2009 | Black & Decker Garden
Must battery be at full 12v charge to start mower
lawnmower batterys usually dont last as long as one would like maybe you should buy a new battery.you might try jumping the mower with a car as long as the mowers battery is 12 volt
Apr 06, 2009 | Garden
Black & Decker Cordless lawnmore CMM 1200 - battery
I bought my B&D cordless mower CMM1000 (very similar to the CMM1200) in April 2003. I made the mistake of following their instructions and stored it inside unplugged the first winter. Never again! The battery would not hold a charge April 2004, but was covered under warranty. Since then, I've left it trickle charging in the shed year round, including cold winters. No problem since then with the battery, which will last about 5 yrs before you need to replace it.
Nov 29, 2008 | Black & Decker 19" Electric Lawnhog...
B&d cmm1000
see if ur mower is cmm1000 type 1 to 4.this unit are recall for
board. see service center to upgrade the unit to CMM1200. if ur battery are not holding charge need the battery is not parts of the recall.battery will last 3 to 5 yrs apx.
Aug 15, 2008 | Black & Decker 19" Electric Lawnhog...
I need the large cordless battery for the black and decker cordless mower, and also need the power charging board in the mower.
the largest is the 24v CMM1000. now the circuit board for the said model are hard to get. but upgrade are available & convert it to CMM1200 model. convertion kit includes instruction how to, a wiring assy & a charger.
Jul 03, 2008 | Black & Decker 19" Electric Lawnhog...
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
1,595 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
