Question about D-Link Express EtherNetwork DI-604 Router
I typed the wrong model number for the Router I have a problem with. It is a DI-604 4 port wired router.
  • 35 Answers
Great. Now try to post the entire question so we can know what you are asking.
Posted on Sep 26, 2010
I need to know if the D link DI 604 Router can be used for a wirless networking
No, is the short answer. It only has the 4 ports which have to be wired with ethernet cables. So this Router is a wired router.
Mar 25, 2011 | D-Link DI-604 4-Port Cable/DSL Router...
WHEN I DIRECT MY INTERNET WIRE I CAN CONNECT BUT WHEN CONNECTING IT TO ROUTER I GET LIMITED CONNECTIVITY.
It means that the router is not configured yet. First, you have make sure that your internet wire is connected to the WAN port of your router and the computer should be connected to one of the LAN ports of your router.
Check the LEDs. Be sure that the LEDs for WAN and LAN where your computer is connected to is lit up or blinking (will depend on the brand and model number of the router).
Then you need to access the Web Utility of the router to set it up correctly. You need to refer to the manual of your router. Having a router does not mean that it will work immediately once you connect your internet or modem to it. It needs configuration.
You may also contact the tech support of your router (since the brand was not provided) for assistance
Thank you!
Oct 22, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
I have D-link cable router(DI 604)..i want to
http://www.antifart.com/2006/09/02/d-link-di-604-firmware-rev-e.html
Before using these files, make sure you have the E Revision of that router, you can check by looking on the sticker that contains all the model information like serial, model number.
Be careful while doing a firmware upgrade, very easy to brick your router. Bricking refers to making the router no more useful than an expensive paper weight.
Oct 20, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cant share internet using a router
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be 192.168.1.1, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Mar 12, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
No connnect no connect to lan
Try reseting the router. (insert a pin into the back hole and hold on few seconds)
Then try typing the default address
http://192.168.0.1
User= admin
Pass= (blank) no password
Try accesing the router thru another computer
Nov 06, 2008 | D-Link DI-604 - 4-Port Broadband Router [...
D-LINK DI-604 STATIC IP
Log into the router and go to the configuration page for your WAN port. Change the connection type to static ip.
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link DI-604 Router can be use in Wireless Broadband?
You can use any wireless access point. If you would like to stay with Dlink, you could try the DWL-2100AP. You would just need to plug it in to an open port on your router.
Dec 28, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
No response from the DI-604 D-Link Router
The cable must be of parrallel type......(not cross)... connecting router and the modem or PC...
Dec 23, 2007 | D-Link DI-604 4-Port Cable/DSL Router...
D-Link Express EtherNetwork DI-604 Router Logo
24 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
