Question about AEG Dishwashers
The door keeps opening mid cycle and now the catch is permanently in th eclosed position which means I cannot shut the door. Can it be reset? AEG favorit 44070 VIL
I dismantled the door and reassembled the catch. It seems to work ok.
Posted on Apr 22, 2008
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
Turned off mid cycle. Tried putting back onfor drain, also rinse and restart. Each time get error E40.
Hi.
With AEG washers E40 means defective door lock. Since a faulty door lock switch may go out with vibration you often do not get the error all the time. The door lock switch must be tested and eventually replaced. Call the AEG number listed in the user manual if you want to get in touch with an authorized technician or if you need replacement parts for your washing machine.
Regards.
Ginko
Sep 18, 2011 | AEG Washing Machines
Why does my dishwasher keep popping open during a cycle?
Hi, the problem is that there was too much resistance to the door closing. You have to pull off all the rubber gasket that press against the door, clean it well, re-installed it and the resistance will go. It's a easy permanent fix, just do not stretch the gasket as you put it back in.
Jun 22, 2011 | AEG Dishwashers
My dryer keeps shutting off mid cycle
OPEN THE DOOR AS SOON AS IT STOPS AND TEST THE TEMPERATURE IT COULD BE A DODGY THERMOSTAT
May 12, 2010 | Kenmore 65924 Electric Dryer
Boxster power windows reset after battery replacement..cycled down and up but can't seem to get th windows to cycle down 1/2 when opening
Open both doors,lower windows
Shut doors,raise and lower both windows twice
Raise both
Check opperation, should have reset.
Jan 08, 2010 | Porsche Boxster Cars & Trucks
Door latch in closed position
put two small screwdrivers in each side of the latch and lever upwards (best way) or otherwise take the door outer panel and fascia off so you can get at them
to stop it reoccuring, bend u catch on cabinet slightly downwards
Jul 20, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Washing machine door sensor
I must differ with you. This machine does have a computer control card located within the timer base assy. Thee 5 beeps are a response from the computer that informs of a faulty signal between the computer and the door sensor
Nov 09, 2006 | Roper RAS8445KQ Top Load Washer
Dishwashers Logo
577 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
