Question about DeLonghi Kitchen Ranges
I have a Delonghi DFS901ss oven with what I think has a faulty oven function switch.The oven will either work properly,warm or not function at all.The grill, fan and other functions are still working. Is it a fairly straightforward job to replace for a reasonably competent person!
Yes it is no problem just replace one wire at a time to make sure there go in the same place
Posted on Sep 15, 2008
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
Easytronic deloghi microwave, all electrical functions working ok but does not warm food. please help
Please check the start button if its functional. The timer must be counting once you press the start button. Check also the air filter if it has dirt and dusts . Some ovens are equipped with sensors that disabled the unit once the air filter becomes dirty.
Nov 04, 2010 | DeLonghi MW 605 Convection/Microwave Oven
.oven not working delonghi DFS901SS. light on dial
Hi Lyndsay,
Sorry to hear about your oven,
Are you in the GTA , If so call 905-501-8436 for a free quote
If you are elsewhere , how handy are you or a friend.
With the plug pulled, put a Ohmmeter across oven elements.
They should short out. That is good. if not replace element that didn't short out.
If both elements work then it is you thermistat, which is not to hard to replace
Aug 05, 2010 | DeLonghi Ovens
It turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Delonghi esf461st oven not heating up
grill element is separate from oven element. i assume this is a fan oven. take rear panel off inside the oven and the oven element is exposed and you can often see the damage. toncheck properly, take the rear cover off outside the oven and terminals of the element are in view. check for continuity with a multimeter
Sep 06, 2008 | Ovens
Delonghi DFS901SS
have the same problem as you all. i myself removed the top of the hob to reveal a burnt out control switch . i have looked online for a replacemrnt , and it is £66 plus vat from delonghi but have found a cheaper one for £42, cant remember which site it was but type in cooker name and model on google and you will see it for yourself . good luck to you all, it seems like an easy fix
Mark
Oct 21, 2007 | Ovens
Kitchen Ranges Logo
414 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
