Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a manual with an electrical diagram.
My riding mower refuses to do anything electrical. Battery is fully charged. There is power into the ignition switch. I believe that one of the safety switches such as on the seat, on the brake pedal, or elsewhere
is malfunctioning, but cannot locate the exact problem.
    Sergeant:
  • 200 Answers
The fuse is blown under hood behind engine.The coil might be bad at the worst.
Posted on Jul 19, 2010
I need to check electrical system in my riding mower
Check your battery cables all ends. and see if they are loose or corroded. Just an Idea. Check all fuses if you have any.
Dec 07, 2016 | Craftsman Garden
I have a Troy-bilt riding mower with 20 hp Kohler engine. Battery was going bad but I was able to charge a few times successfully. The last time, the seat fell forward onto the charging battery and
Okay according to the electrical diagram the lights are powered by the alternator only when the engine is running so the engine must be cranking. If so then you may have somehow reversed charge the system. If so then the ignition coil would be blown and possibly even the alternator depending the engine setup. It doesn't take much more than momentary reversal to do this. When cranking test for spark at the plug gap while is removed and grounded. If no spark I would think the coil has died. If you getting a spark then check fuel cutoff solenoid on the carburetor to see if it working even a reverse 12 volts won't hurt it.
I am including a copy of the electrical diagram so you can do electrical checks on the system, Good Luck
Electrical Diagram
Nov 15, 2014 | Garden
Mtd yardman lawn tractor
Not sure if your model number is like 13AX614G701 It is likely the solenoid is not working, This is the component that would start the mover. See this diagram.
Replacement Solenoid 925 1426A for YARDMAN Lawn Garden Yard Farm...
Aug 21, 2014 | Garden
My troy bilt riding mower wont crank
Check your battery and see if its fully charged. I had a battery that the charger said was fully charged but a cell was dead. Take it to a battery store and they will check it free of charge.
If that's not the problem check all the battery cables on both ends for being tight and clean. If that's not the problem you could have a bad starter.
Jun 22, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Lawn tractor wont start
How do you know the battery is fully charged? Simply hooking a battery up to a charger does not ensure that the battery is being charged. The symptoms you mention are indicative of a dead battery.
Jan 29, 2014 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Snapper nxt no power
no voltage. blown fuse, poor connection at the battery cables. you need a wiring diagram to test further. If you can't read the wiring diagram. seek professional help
Nov 19, 2013 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Aug 27, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
181 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
