Question about Sewing Machines
Took stop motion knob off how do the pieces go
Took stop motion knob off of jcpenney 6915 sewing machine..Now how do the pieces go back on correctly?
  • 980 Answers
You should have a three pronged washer, put that on first anyway round, then put the stop motion wheel on and tighten fineger tight, tighten the small screw that should be on the stop motion wheel and tighten a bit more, if it does not tighten up take the stop motion wheel off and put the three pronged washer in a different position.
Posted on Jul 18, 2010
Release stop motion knob won't move
What are you calling a stop motion knob? Are you trying to stop the needle from moving while winding a bobbin?
Jan 31, 2014 | White Sewing White 3032
VX808/Vx809. When put pressure on foot control stop motion contro doesn't move.
I would suggest that the machine needs to be serviced to find out why it not responding the way it should.
Mar 22, 2012 | Brother Sewing Machines
Old JCPENNEY # 6915 Sewing Machine Manuals
check with the sewvacdoctor.com & ask them about the manual
Feb 23, 2012 | Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
I turned the stop motion knob in order to wind a bobbin and the knob fell off! I have tried to put in back together but now only the knob will move not the balance wheel. As as result the clutch will not...
There should be a washer that fits over the balance wheel, if you dont put that back on the machine wont work.
Check around and see if it fell off when you removed the knob, or check to see if it is stuck inside the knob.
The washer is about 1" in diameter with a couple little tabs on it.
It will only work when installed correctly so if at first you fail just turn the ****** over!
Aug 26, 2010 | Janome L-344 Mechanical Sewing Machine
Stop Motion Knob
Dear Jim,
I'm sure you have a pair of Channel lock pliers around.Place a fairly thick piece of fabric around the inner knob to keep from scratching it. Grasp it with the pliers while holding the handwheel and turn it to the left. IF you can't hold the wheel to keep it from slipping, place a screwdriver or something else under the needle set screw area, turn the wheel until the set screw is resting against the set screw and then turn the inner knob with the pliers.
sewman7
Aug 31, 2008 | Sewing Machines
Sewing Machines Logo
507 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
