Question about Foxconn 925XE7AA-8EKRS Motherboard
Shutting down PC
Why does my PC shutdown and start right back up, when I use the shut down option in Windows XP? I have to use power button on back to shut down.
  • 30 Answers
This is usually caused because one of the PCI cards attached to the system is sending a Power On message to the PC. This is usually due to a short in the PCI device, but can also be due to a short on the motherboard itself or a faulty BIOS image.
You can try updating the firmware on your motherboards BIOS, and unplugging different PCI cards to see what is causing the issue. Additionally you could try turning off ACPI in the BIOS, but this will require you to press the power button after Windows Shuts down. This also doesn't allow you to do any advanced power management things like put the pc to sleep.
Posted on Apr 22, 2008
Laptop doesnt shut down
With xp you a have to select
Start --> the right arrow --> then shutdown.
Aug 27, 2012 | HEWLETT-PACKARD HP ProBook 4420S NoteBook...
My computor wont shut off like it should?
Wthout some more info it's hard to say, but if, when you turn it of, you see the phrases "Preparing to hibernate" or "going to sleep" or basically anything other than "Shutting down" then the correct option to shutdown needs to be selected. On windows XP, click the start logo, select "shutdown" then select "Turn off computer". if you are using Vista, in the start menu, click the arrow next to the power icon then click "Shutdown" with windows 7 just click "shutdown" in the start menu.
If you are trying to turn off your machine using the power button on the machine or on the keyboard, the machine will hybernate by default. To change this, go to "control panel" select power options and edit the current power plan. Look for the setting "change what the power buttons do" or something like that! change it to "turn the computer off"
Hope this helps.
Jan 13, 2011 | E-Machines eMachines Desktop PC
I press the power off button and it doesn't power off
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Oct 17, 2010 | HP Pavilion dv7-1245dx Notebook
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
I just bought a sony VIAIO today and dont knoiw hoiw to shut it down
1. Normal shutdown: select Start - Shut Down - Shut Down
2. System hangs: select Alt-Ctrl-Del and then Shutdown
3. If #2 doesn't work - hold the power button until the screen is dark
Hope this helps.
Aug 17, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
How to make easy shutdown a pc
In windows xp or vista you make it easy, using press the power button in the windows environment, it will auto matically shutting down the pc.
regards
Krishan
May 11, 2009 | Computers & Internet
Windows XP not shutting down.
hi im josh in cebu phils. Friend it is just a simple problem not to be worried of. Actually is not a hang up problem it will shutdown but it takes time.a delayed time or longer time it was set. All you have to do is to go to bios/cmos setup. restart your pc then press f2 if it ask to enter setup or mostly hit del to enter setup. once you have entered the setup you choose the power management then adjust the power off delayed to shorter mins. or you can choose direct off.just select what you want there.it will solve your proble and dont forget to save before you exit so that it will be applied to your pc. hope i helped you good luck!
Feb 19, 2009 | Computers & Internet
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
HP dv6835tx Notebook with Visa Ultimate 64-bit will not shut down
From what you've described, it sounds like you are clicking the Standby button, instead of the actual shutdown option. On the Start button, you will see (from left to right); Left: Start Search Middle: Standby Middle: Lock Right: Arrow Clicking the arrow will show you the Shutdown menu option; http://blogs.chron.com/techblog/archives/shutdown.jpg
May 26, 2008 | Computers & Internet
Foxconn 925XE7AA-8EKRS Motherboard Logo
118 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
