Question about Samsung SyncMaster 920WM LCD Monitor
Samsung syncmaster 920wm after a few seconds from when monitor is turned on goes black if i turn it off and then on again for a second or 2 i can see then goes black again.
    Genius:
  • 1,478 Answers
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Posted on Jul 18, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Oct 04, 2014
As far as I can tell none of the capacitors look like that. I will keep investigating. Thank you for the quick response.
Posted on Nov 15, 2011
I know this was answered over a year ago. But the solution that jimoh mentioned is incorrect. I had the same issue 2 hours ago. The issue is a bad capacitor located on the power board. Its a easy fix if you know how to solder. Look for the capacitor that is pushing upwards. You can compare them to the flat un-blown ones. What ever one is bad, gather the information on it mine was 1000uf 10v. Get that from radio shack or any device like a spare computer supply or vcr and replace it. Once you do that it should work. I fixed it in 15 mins and didnt spend a dime. Best of luck and hope this helps many others.
Posted on Nov 04, 2011
  • 1 more comment
  • aaron Nov 15, 2011
    Rob, can you give some more detail please. I see the capacitor you are talking about, but I do not understand what you mean by one that is pushing upwards compared to flat ones.
  • rob lau Nov 15, 2011
    The capacitor will be pushing out. the metal with the lines on it will be rounded out because it blew. Kind of like a soda can dropped. Where you go to open it. It will be pushed out. Look for ones like that. If you find it remove it and replace it with the same specs.
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Samsung syncmaster 172v Screen goes black after about one second. Comes back to normal after turned off, but goes black again in about one second. Rebooting computer has not fixed this.
Sorry it is like your monitor needs service. Electrolytic condensators in power supply need to be changed. Give it to an electronic shop, it is a job for a specialist.
Oct 18, 2010 | Samsung SyncMaster...
Samsung SyncMaster 174v will display image for 2 seconds then go black. When I turn monitor off and then on again, it displays image with normal brightness for 2 seconds and then goes black. When I plug...
Hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website www.micromendllc.com. Thanks
Mar 10, 2010 | Computers & Internet
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
My Samsung Syncmaster 906cw LCD turns on then goes almost black.
I have the same issue with mine...did you get any help on this?
Mar 30, 2009 | Computers & Internet
LCD display turns pink then goes off
You may be blaming the wrong device. I suggest you try the monitor with another system, the problem you describe could be located in the video output of your system instead of a monitor fault.
Feb 28, 2009 | Samsung SyncMaster 920WM LCD Monitor
Samsung SyncMaster 920WM LCD Monitor Logo
1,210 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
