Question about Brother MFC-5840CN All-In-One InkJet Printer
MFC-5840CN "unable to clean" and "machine code 50"
Hi.
my MFC 5840CN stopped printing Black and Yellow even after repeated head clean operation. I was told that as i'd used self re-filled ink and not used it up in 6 months (as I print fairly infrequently), there was probably a blockage in the ink delivery system and it would be uneconomic to pay for repair, so i tried myself. There were bubbles in the tubes and ink wasn't coming out of the head, so i took printer apart, flushed through using JR Inkjet Flush fluid and reassembled. I'm now getting "unable to clean" message and when I try "menu/mono print/^^^^" I get "machine Code 50"
I've cleaned the encoder strip ribbon (but there is a slight stain on one part), as i read that this cound be cause of code 50, but still no joy. Can you help?
KMW
  • woodkm Apr 22, 2008
    I'm pretty sure that the strip is properly back in place. One thing, though. I removed the strip to clean it and I can't be sure that when I refitted it I put it back the same way. would it matter if I'd fitted it "upside down", or swapped from L to R...or even both of these? There are is a code printed on the strip. Can you confirm the correct placing and attitude for this. Thank you
    KMW
  • woodkm Apr 24, 2008
    Right then, encoder strip fitted correctly
    Now getting "Unable to init." and "Machine Code 50"
    any ideas?
    I've had to promise that if I can't resolve problem tomorrow I'll have to get a new printer.
    KMW
  • 832 Answers
You have to fix the encoder strip into right position within the ph carrier! do push the head left/right to see if there are waves infront of it. if so, fix the strip into position!
BTW:
If you refill your carts use 2ml glycerol (from drugstore) with 10ml dye-ink: mix well before refilling. For bk use 1,5ml glycerol with 20ml bk dye-ink.
The glycerol prefents the ph/nozzels and tubesystem from drying up!
Posted on Apr 21, 2008
  • Mix-it-up
    Mix-it-up Apr 22, 2008
    150 /\ must be readable and on the right hand side (purge station)
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
The black will not print. I have replaced the cartridge with two new ones. Color prints ok. Brother mfc 5840cn
please perform head cleaning to see if there is any ink out.. goto ink management and select head cleaning... after that goto ink management and print the nozzle check.. see if there is any black ink out...if no ink out..then more probably your print head is badly clogged..and you will need to get it replaced.
Jun 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
No black ink printing
Ah, solved already. Cleaning the black print head a few more times did it for me.
Mar 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
Message window reads "unable to clean" and machine will not print period
Press:
Menu/Set, Black, Up arrow 4 times, 80, then press black until "Purge" appears on the screen, then press 2783, stop/exit, 99.
Jul 18, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN Unable to clean
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Apr 25, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
3,229 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
