Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
I have the same problem , and Like the the person who asked the Question ,, there is no Blockage ,, Im thinking maybe these filters have a very short life span ,, and even cleaning theses filters with a brush, etc , may not be enough, and could have to be replaced. I have great suction, before the filter, but really non after the filter..I have taken apart all areas that could be blocked , with no Blockage anywhere...I ll follow up on this and let you no the Solutionj soon thanks Rick
Posted on Aug 05, 2010
  • 3 Answers
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Posted on Jul 29, 2010
There is too much suction even with the hand tools on Hoover wind tunnel. Can i adjust suction somehow?
Hi, it's Jeremy from Crucial Vacuum.
If there is too much suction, adjust the nozzle control knob to a higher setting. The knob is located on the front of the vacuum at the bottom. For optimal cleaning efficiency a low setting should be used for most types of carpet and for hardwood floors, tile, and deep carpets use a higher setting.
You can purchase direct all of your replacement filters, bags, and accessories for your Hoover vacuum from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 17, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled wind tunnel doesn't self propel going backwards.
Your self propel cable sounds like you need to have an adjustment. reccomend a service shop repair.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 25, 2009 | Hoover Vacuums
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
Why wont the self propelled brush on the hoover wind tunnel work. large belt is ok. the small belt looks 0k.
no don't do that,have a little patience.check where the self propelled assembly is and see if anything got in there,something might be loose and the teeth are meeting each other.thats a good vavuum.i have 2 but their not self propelled.try taking the belt off the self propelled machanisn and try it again.if it works then something is keeping the propelled machanism from working.dig a little deeper,what do you have to lose?
Mar 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
I have little suction when using the hose attachment
Check the hose for a blockage. If you remove the hose, if there is suction at the point where the hose hooks to the back of the vac, then the hose is clogged. If no suction there, check filters, make sure they are clean.
May 31, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Wind tunnel hoover
Do you have suction at the hose end, if you do then it may be clogged at the inlet by the brush roll. Is the filter cartridge clean? If it is clogged and air can't pass thru it, then you will have no or low suction. Might also check the belt to make sure it is turning.
Nov 30, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover Wind Tunnel Upright Self-Propelled
Thanks to reddevil6. Sure enough it was the belt. What I did was take off the belt and flipped it over, worked like a charm. Since it was stretched on one side the other side was still ok. Still need a new, but s aved me a trip to the store!
Nov 21, 2007 | Vacuums
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
212 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
