Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a cub cadet model 18m walk behind mower. it has been running fine but the automatic throttle is not working so the motor is at a low idle. ansugestions . i have checked the plug and air filter they are ok I can rev the motor but hand with the govenor. please help the grass is getting out of control
nobby63
  • 10 Answers
SOURCE: What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
Posted on Jul 09, 2009
  • 133 Answers
SOURCE: I have a self prepelled cub cadet walk behind lawn
take the bad wheel off and see if the cogs molded into the wheel are stripped replace if so
Posted on Aug 02, 2009
  • 11 Answers
SOURCE: Mower stolen.
$249.00 or try home depot.com
Posted on Aug 11, 2009
  • 548 Answers
SOURCE: cub cadet 18m, one year old won't start
try cleaning the air filter and make sure no grass is stuck under the guards (build up) do this while not running of course lol
Posted on Aug 21, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
Removing lawnmower blades
check the belt that goes from each blade there is a timing mark on them
Aug 28, 2012 | Mtd Cub Cadet 33 In 344 CC Wide Area Cut...
Timeing pull cord rip out of hand when trying to start mower model 18m
what you have done is sheared the flywheel pin top of eng pull fly wheel you will find a schered pin go to lawnmower shop possible with pin get replacement just a few dollars you be back in timing and back to work let me know if you need a walk thru sparks
Apr 22, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 18m, one year old won't start
Aug 21, 2009 | Garden
Bought my Cub Cadet 18M from Home Depot in September, 2008. Only used a couple of months. Trying to start the thing now and it is impossible. Will start for a few seconds and then shuts down. I live in...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I was ‘gifted’ with a non-working Cub Cadet 18M mower a few weeks (July 09) ago by a neighbor. The mower was purchased in the Summer of 2007 and exhibited the same problem as yours (started briefly and then died) in late 2008 and was then abandoned in the weather until it was given to me.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The carburetor is held against the ‘intake’ side of the cylinder head by two threaded studs via a gasket, a stamped sheet-metal heat shield (approximately 3.5 x 5.75 inches), a short black plastic manifold, and another gasket. The heat shield tends to vibrate in resonance with the engine vibration; this vibration eroded the gasket between the heat shield and the carburetor mounting flange to allow ambient air to enter into the gas/air flow into the intake side of the engine. This extra air “leaned-out” the gas/air mixture causing the engine to die.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I disassembled the components and removed and discarded the heat shield and its gasket and made a new gasket out of oil-wetted index-card stock. The machine now starts on the first pull and runs well.
Jul 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
188 people viewed this question
Top Cub Cadet Garden Experts
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
