Question about GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator
I have a GE model # PFS22SISBSS can't set freezer temp to 0
I have a GE model # PFS22SISBSS and the the adjust freezer temp is set for 18 should be 0 and the adjust refrigerator set for 41 should be 37 when I try to set it to the default setting after 2 sec it gos back to what it was before I need help
mikedurland
  • 481 Answers
SOURCE: I have a GE Profile
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 01, 2008
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
  • 74 Answers
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Posted on Feb 26, 2009
  • 37 Answers
SOURCE: What is the answer to puzzel 5, 18, 23, 27, 28,
Puzzle 5 -- Answer is Ten Times 10
Puzzle 18 -- Move Top far Right Match to Left of the Dust-- Move Middle Match slightly Left to make the Handle.
Puzzle 23-- Empty 8 (Litre Pitcher) into 5 (L.P) Empty 5 (L.P) into
3(L.P) then empty 3 (LP) into 8 (L.P) then 5 (L.P) into
3(L.P) then 8(L.P) into 5 then 5 (L.P) into 3.(Litre P.)
Pour contents from the 3 (L.Pitcher) into 8(L.P) You
will have 4 Litres in two of the Pitchers.
Puzzle 27 -- Bickering Brothers -- Sit them clockwise from the top
as follows -- 1-- 3-- 6 -- 4 -- 2-- 5 -- .
Puzzle 28-- Find the Dot. Bottom Point on the Right.
Puzzle 36-- Only 1 as the mouse you bought was a MALE
Puzzle 37-- Brother & Sister-- They were Twins Age--- 6 (SIX)
Puzzles 38 - 41 -112-- are all quite easy, just play around you will get the Answers.
Posted on Apr 13, 2009
  • 61 Answers
SOURCE: Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Posted on Jun 08, 2009
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
ICE MAKER NOT WORKING ON GE PFS22SISBSS
Lets try this first. Unplug and then wait 10 minutes and then replug. That should reset the memory for the motherboard. If that does not work contact me asap, Sea Breeze
Mar 13, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
I now have same problem as arjaybeee posted on Oct 29, 2009 PFS22SISBSS digital temp. control LEDs not lit, so can't see the settings for fridge or freezer spaces. The spaces are being cooled, though, but...
It may be as simple as a blown lamp bulb.
Check item #624 on the diagram at this link. You can also order your part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218255&diagram_id=26230025#d26230025
Jan 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
The freezer temp is down to 18 tried to set @ 0 temp is not changing also refrig is down from 37 to 40 .
This is either a compressor or the thermostat failure. Replace it, It will solve the issue. Thank you, Have a nice day.
Sep 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
My freezer on my GE GSH25jfta BB will not get above 0 degrees even on the lowest setting. I have tried adjusting the temp from 1 to 9 with the same 0 degree reading. Could it be the thermostat?
your refrig's frzr temp is designed to be around 0 degrs. in order to give you a 35-40 degrs. temp in the freshfood side. you might not have a problem at all. check temp sensors and main brd in the rear.
Jul 14, 2009 | GE GSH25JFT
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer temperature swings
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
Jun 24, 2017 | GE Freezers
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator Logo
224 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
