Question about Maytag Atlantis MDE7400AY Electric Dryer
My dryer is leaving black marks on all my clothes and it sounds like sand or beads are rattling in the drum.
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryermy dryer is leaving black marks on all my clothes - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 18, 2010
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
Kenmore 500 series dryer is eating clothes, clunking and leaving black marks. Clothers are getting stuck in the drum in back of dryer. Any suggestions?
It sounds that the rollers a roller went bad and or the front/rear seal now has seperated, your drum now misaligned. Depending on model.
Dec 28, 2011 | Dryers
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Dryer
nothing in the dryer i.e.crayon left in pocket?? there is no black grease used in the unit only White lithium style.. I dont think it came from the inside of the mach ...Best bet is to clean the tub out mild soap and a damp cloth it should go away. if not the peice maybe stuck in the baffles manually spin the drum do you hear anything rattling around?? Let me know
Jan 26, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
283 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
