My toshiba satellite M305DS4829 screens blinks and turns white when I move it.
    Brigadier General:
  • 10,406 Answers
It's a loose "data" cable between the motherboard and the LCD display -- jiggle it, and it loses its connection.
Since this is not a "user-replaceable" part, take the computer to a qualified technician, for professional trouble-shooting and repair.
Posted on Jul 18, 2010
Hi, I have Toshiba Satellite A305 S6905 model.
It is more on a hardware issue. The battery needs to be drained. Once on, let the battery drain and re charge it for 4 hours.
Oct 29, 2013 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
I went to move my Toshiba p205 notebook from the desk to my bed and the screen turns white I've tried restarting it and window Vista makes the start-up sound but nothing comes up on the screen except a...
HI:
Try taking out the battery and leaving the unit unpluged and free of power for at least ten minutes. Then try restarting the unit normally, if the screen is still white then this means it is not receiving data from the graphics processor, if so then this is a indication of a faulty video processor or graphics chip, you may of gathered static electricty while walking across carpet that may of shorted the chip. In which case the only thing that can be done is to either replace the mother board in the unit or send it to toshiba for repair and replacement of the main board, you may want to contact Toshiba first before going futher as they may have a solution for you.
Dec 19, 2010 | Toshiba Computers>Laptops Satellite A10 PC...
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Blinking white dash during boot.
Something has messed with your MBR, master boot record, which is a small sector at the beginning of your first hard drive which tells the bios which partition to boot. You'll have to use your xp or vista's installation disc to repair the system.( Choose; repair this installation of windows when prompted )
While you are in the bios check under the boot section the order of your boot devices. If you have more than 1 HD check that the one containing your OS is first.
May 08, 2009 | Toshiba Satellite A105-S4384 Notebook
Toshiba a75 s-206 cuts on than idk!!!!helpppppp!!!!!!!!!
If you put in a Windows CD does it boot into the cd menu?, does the black screen have the blinking white line at the top left corner?
Mar 05, 2009 | Toshiba Satellite A75-S206 Notebook
My Toshiba satellite A205 turns black
seems your OS got stucked so remove your all external devices if they are connected (ex. pen drive, Ipod CDs etc)
and reboot your PC once.
if still does same then you need to repair your PC using recovery or OS disk.
post back if anything changes.
Good luck
Feb 07, 2009 | Toshiba Satellite A205-S4707 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Open Questions:
How To Write Archaeology Research Papers, Term Papers & Thesis? Archaeology term papers and research papers mostly follow the APA or Harvard style according to the requirement of the paper and on the word count. Writing an archaeology paper can seem a daunting task when toy are new to the field itself or have just started learning regarding a new site or culture. But it doesn't need to be so. To learn extensive knowledge about a specific topic To collect information from extensive sources and compile them To come up with conclusions To ensure that there is no plagiarism in the paper. The brief guide for essay writing given below will ensure that you get a well-written paper. Pick a Topic Your professor has asked you to write a research paper on an archaeological site or culture but you are unsure what to write on? Here is the sequence of tips to come uo with the perfect topic for your research paper. Conduct Background Research Literature review is one of the most important parts of background research. It is conducted by an archaeologist before initiating archaeological studies in an area or at a site. The same tips are also applicable towards finding articles and books regarding a topic. Reading Your Background Research We know you are in college and know how to read properly. Still, when it comes to the importance of understanding an issue thoroughly and synthesize the knowledge gained from reading, avoiding plagiarism and giving your opinion and conclusion, you would be advised to take some help. Writing a First Draft Writing a first draft for your research paper in archaeology doesn't have to be a daunting process if you take one step at a time towards preparing your draft. Writing and Editing Your Final Draft Writing a final draft of an archaeology research paper is undoubtedly the hardest part since writing styles vary between people so much. The recent history of archaeology suggests that the field has been increasingly moving towards professionalism and an ever increasing number of tools and techniques to use with the intention of get as much information as possible on a site that is examined. There is no one single theory of archaeology and any attempts to define the field has been unsuccessful because of disputes regarding their accuracy and relevance. During the middle of the twentieth century archaeology was thought to be closely tied to anthropology and history. In essence, archaeology itself is based on the study and examination of human cultures through the processes of recovery, documentation, and finally analysis of material remains as well as environmental data such as architecture, bio-facts, human remains, landscapes, and artifacts. The primary goal and purpose of archaeology are to document and provide an explanation regarding the origins and development of human culture, its chronicle evolution and develop an understanding of the history of culture. It also intends to study human behavior and ecology with regards to both prehistoric as well as historic societies. In the US, archaeology is considered to be one of the main sub-fields of anthropology. The study of archeology is a science and a humanistic endeavor. The goals of archaeology are far and wide and there is ongoing debate regarding its aims and responsibilities to the society. One of main goals on which there is some consensus is that the field intends to document and provide explanation of the origins as well as development of human cultures. Archaeologists also study the various methods used in the discipline and the theoretical and philosophical ideas that underpin the questions that inspired questions archaeologists in the past. The tasks of surveying regions around the world to locate new sites and excavating them to recover cultural remains, to classify, analyze and preserve are the most critical parts of an archaeological process. Each of these parts provides a great amount of information regarding a culture and the past. As such there is a need to present professional research papers and term papers that have to be written in the study of archeology.
Feb 23, 2018 | Final Draft Computers & Internet
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
