Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
The printer gives the error 07,010.43:44294
I was copying some documents when this happened. The printer overheated and now says this error on the console.
  • 45 Answers
Okay, What "Tryit" solution is correct. The main problem with this printer is the printerhead. The error stands for, "PRINTHEAD UNABLE TO TILT" technically. The issue is the print head tilts in order to wipe and print on paper. The cause of this issue could be the steel block being clogged up unabling the print head from tilting correctly.The other cause with my C2424 was that the printhead was cracked, so wax was building up all along the bottom the left and right sides and clogging the print heads movement. Clear the wax and the printer should work. If it works for a good while but continues to spill wax, your more than likely to have a cracked printhead. You should replace it. It will definitely solve your issue.
Note if the wiper is stuck there are gears on the right side of the printer that can build up wax causing it to not be able to move.
I hope this helps. I've fixed this issue on numerous amounts if you would like to ask me a question feel free to do so. I hope this helps.
Please Rate :) Porfavor
PS... Better yet if you want step by step instructions please comment back or i can help in person.
Posted on Oct 15, 2008
  • 2,072 Answers
That is a print head pivot error.
1 of three things,
Most likely the is ink in the print head block. On the left side, ( looking from the front) with the side cover removed, the block is about midway back towards the bottom of the machine, A staineless steel block about 1 inch square. What usually happens is ink seeps into that block and the print head does not move from home to print position properly. The block is just held in by a spring on a bracket. You pull it back and latch it to the left. Remove the block, Which may require some channel lock type pliers to remove. Then clean the block and the print head shaft completey and remove excessive ink around it. Replace.
It helps to soak the block in some hot water for a minute or so to losten the ink.
2. issue number 2 would be the wiper blade stalling between the print head and drum. I less likely suspest that since it happened during a run. But to access that you have to remove the scanner, both the right and left cover, a small cover on back and the ink loader, where the sticks go into the machine. That will access the area between the print head and drum. Look to see if the blade tacked to the print head and pry it loose. Then run a eliminate light stripes mode and remove smears.
3. The print head cables may be a bit tight and binding the print head or check those while in the print head area.
If that doesn't eliminate the problem, let me know. I strongly suspect the print blockbeing dirty, thats the cause probably 90 percent of the time.
Let me know for sure, We will get this resolved for you.
Posted on Apr 21, 2008
Printer error see your documentation
My name is pramod Mahajan My printer problem epson office 620 printer start now properly but send the print so printer display Printer error see yaour documention. so plese give me solution
Cannon d1320 false paper jam
this happens due to overheating of the fuser unit.try resetting it
Jan 25, 2014 | Canon Imageclass D1320, Copy, Print, Scan...
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer problem
try to un-install the printer and re-install it again and see if this will work with you
Feb 09, 2009 | Canon Office Equipment & Supplies
When iam giving the print for 2 copies, then the 2 copy will give
most time the printer formatter happens to go that way too..
Feb 05, 2009 | HP LaserJet P2015 Printer
Faxing and copying
clean the big rubber roller on the document feeder with windex applied to a micrfiber cloth and then try to fax or copy two sheets
Nov 27, 2007 | Canon imageCLASS D880 All-In-One Laser...
you can try this method and see if it overrides the printer counter.When you go to print with the ink and it gives the error press the black copy button on the printer then the color one after another way is..just try to copy any document load some paper then press the black copy button like if your doing a black copy then the error should come up,press black copy again and that should override it,do the same for the color goodluck.
Nov 22, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
247 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
