Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe odd burning smell
We have owned the Saeco Vienna Deluxe for 2 years and use it every day. This morning it made a different sound during the process and I then smelled something like the motor burning. Can I fix this or will I need to send it out for repair?
  • kellydbug Apr 28, 2008
    please advise, it is also making strange noises, , like it is "tight" or being forced to work...
I beg to differ... The grinding motor complete with gearbox is $96 and a piece of cake to replace for anyone with a little mechanical experience... Google saeco vienna spare parts, and you'll find it..
Posted on Dec 24, 2012
    Scholar:
  • 70 Answers
Gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Posted on May 22, 2008
How do I descale my Saeco Vienna Deluxe?
Purchase the Saeco descaler. Mix solution accordingly. Pour into water tank. Run a cappucino cup full of water through the wand. Wait about 20 minute and repeat. Do this until all the water is gone in the tank. (Don't run all the water at once!). Rinse water tank well. FIll with clean water and run through the wand. I do this twice just to be sure I have gotten all the chemical out.
Aug 15, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe
http://cerinicoffee.com/Saeco_User_manuals_free.asp
Apr 26, 2008 | Saeco Vienna Deluxe
Slow coffee drip
did you change coffee different coffee different setting lower our coffee setting move it only when it grinding only cheers
Dec 07, 2007 | Saeco Vienna Deluxe
Manual
Hi
I have a saeco vienna deluxe espresso machine and the coffee comes out lukewarm I just got it two days ago
Oct 27, 2007 | Saeco Vienna De Luxe Espresso Machine
Loud pop does not work
2 things. Brain (main board) could be dead.
Gun shot sound could also be the gears kicking.
Not a good sound and neither is cheap to get fixed. If its both... dump the machine, it'll be cheaper to buy a new one.
Brain plus both gears would hit you 400+ usually.
Sep 13, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
311 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
