Question about Kenmore Washing Machines
I have a kenmore 80 series that will not drain the wash water or spin. Fills and aggatates fine.
  • rhorvathmcs Jul 18, 2010
    Thak you i will try this
  • 1,998 Answers
Hello , ok couple things that u need to check first theres a small gear like object called the drive couple located between the motor and the transmission there is a rubber bushing around this plastic piece make sure that the bushing is intact and that the plastic piece is not broken u can also observe this piece by removing the motor from the machine the pump is located before the motor also check the pump by also removing it as well and making sure nothing is caught inside the pump intake or drain line .if you have no probelm with these two parts then the next one that you would want to check would be your clutch and you check this first by looking under your machine at the round like disc that is ontop of the transmission (note if your clutch is covered in oil this could be why you have no spin function and if it is you would have to replace the transmission)here is another easy test turn your machine on set to spin take your hand on the inside of the drum and spin the drum if the drum takes off spinning and then u can stop it with your hand easily then u need a new clutch if you are not familiar with replacing transmission pieces on a washer machine i do hope that you would call a technician if you want to order the part yourself you could find the part at marcone appliae parts and ask them form the clutch kit make sure u say kit because if you dont you wont get the extra pieces to replace when doing the job the part runs in between 25-35.00 hope this helps
Posted on Jul 17, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As the water won’t drain out so it seems to be an issue with the drain hose, you’ll need to remove the lower front panel and then remove the hoses from the pump to check for any clogs/foreign objects. You can also check the pump assembly which is located in the front right corner. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up...
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Apr 07, 2011 | Kenmore Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
