Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
  • Brad Locke
    Brad Locke Oct 19, 2015
    Take a look under the left foot rest,there is a belt diagram,on how to place the belt onto the pulleys.
    Sergeant:
  • 200 Answers
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Posted on Jul 19, 2010
Transmission loses power when pulling disk changed hydraulic filter motor was rebuilt year ago why im i lose power in transmission? ?
If this is a hydrostatic transmission on a lawnmower type garden tractor some power loss is expected. That just the nature of hydrostatic transmissions.
Severe slippage may not be the transmission itself but would the drive belt. These wear out over time along with the idler pulleys; especially the plastic v-idler pulleys. As the idler pulleys wear out is the same as lengthening the drive belt to a point where it slips. Even a new belt will if these pulleys are worn enough.
Apr 17, 2015 | Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Aug 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding lawnmower, model #917 259012 hydrostat stopped working
Check belts. Check transmission fluid level if possible. Check linkage between shifter and transmission. Check belt tensioners under unit above deck.
Jun 15, 2014 | Peg Perego My First Craftsman Tractor...
Transmission will not go into gear once my riding lawnmover has warmed up
I'll assume you have a 5 speed. Check the ground drive belt and replace it if you find it worn as the unit won't move after it warms up. It's slipping after it gets hot, eventually it won't move at all even when cold. Hope this helps. If it's a Hydro drive let me know.
Dec 25, 2017 | Craftsman Garden
My craftsman will not move when in gear. How do I adjust drive belt?
The belt is not adjustable. That leaves a broken belt, slipped belt, transaxle trouble as your most likely options. Also if you have a hydrostatic transaxle, check the disengage linkage on the back panel. It should be in, not out and hooked.
I hope this helps.
Aug 02, 2011 | Garden
While using my Craftmas 17,5 hp lawn tractor with a snowblower attachment, the hydrostatic drive seems to loose power, especially when it working hard and after its been in use for a while. I don't think...
My name is Dane and I'm going to help you with your problem. First, I believe those craftsman units are sealed and there's no way to actually check the hydrostatic oil level. So the first thing to do is make sure that you don'thave any leaks around the transmission assembly. If it looks clean and oil free, I would venture to say that it is more of a 90% chance that your drive belt is the problem, however it isn't from icing up, but rather from the heat of the extra work from the weight of the snowblower, causing it to slip. The belt isn't all that expensive and before I would get excited and start worrying about transmission failure, I would just replace the belt first, and rule it out. Make sure all your pulleys and tensioners don't have any loose hardware, and look alligned.
I think you'll fix the problem though just by the belt replacement. I hope I've helped. Thank you! Dane
Dec 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What size hydro drive belt can I use to replace the craftsman belt, part# 140218??
The Craftsman drive belt #140218 is a 1/2" by 84.3" belt with an aramid fiber wrap.
Since this belt is contacted on both sides (inside and outside) as it runs the pattern on your mower, it must be replaced with another belt of exact size and construction. If you were to use an 84" belt, then the tension pulley would not have enough slack to disengage the transmission. Likewise, an 85" belt would have too much slack and cause the trans to slip.
The original belt is available through www.searspartsdirect.com for about $25 plus shipping. Check with your local lawnmower repair shop, they probably stock this belt and will be competitive in price.
Oct 29, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My MTD 12.5 hp briggs and stratton ride on mower is losing forward speed as though a clutch is slipping especially going up hills or slopes. MIKE
You didn't indicate what model so I don't know if it is hydrostatic drive or not. If it is not hydrostatic drive, it is most likely a worn belt or clutch adjustment. If you don't have your manual you can download one here:http://www.mtdlawnmowerparts.com/manuals.php
If it is hydrostatic drive it stil could be the drive belt or low water in hydrostatic transmission, or even water in the oil in the hydrostatic transmission. Always list model number when asking questions.
Oct 03, 2010 | Mtd Garden
My craftsman hydrostatic transmission dont want to go up hills what could the problem be
This symptom is cause most often by the following.
Worn and slipping drive belt which is separate from the blade/deck drive belt.(replace the belt).
by-pass lever (rod) not fully engaged (push it all the way in)
travel pedal or linkage is faulty or out of adjustment ( take to dealer)
Transaxle is faulty (take to dealer)
Jul 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
1,129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
