Question about Watts Onan Portable Generator - 5000 , Model# 6500
Onan 6500 less than 2yrs old and used once. Try
Onan 6500 less than 2yrs old and used once. Try to run it every month but it does not keep running. I either drain or burrn the fuel off. Had it in shop a few months ago and replaced plug and battery and 'cleaned it up'. It ran well once after that and since then cannot keep running . I replaced plug again and found it will only run with the airt filter off. Any suggestions?
    Scholar:
  • 142 Answers
Your air filter may be stuck with dirt or moist. Try to clean or change it.
In all cases the problem is in the air duct, if it runs well without air filter.
Posted on Jul 18, 2010
  • parlapanov Jul 20, 2010
    May be I shouldn't have answered you question.
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
On my 9 hp onan genset it runs fine but the 20 amp breaker on makes it shut down is there short or abad breaker
To determine if it is from the breaker use a
Tong Tester
These would indicate what current is being consumed by the load.
Jun 28, 2012 | Watts Onan Portable Generator - 5000 ,...
I have a 1997 onan emerald series GenSet 6500 I have been thru 4 starters it keeps breaking the drive gear assmbly WHAT CAN I DO PLEASE ITS ALREADY COST ME 400.00
Have you replaced the solinoid too? If not, maybe the solinoid is staying engaged, which keeps your starter, well starting. If the starter stays energised the flywheel WILL tear up the starter gear.
hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 04, 2010 | Watts Onan Portable Generator - 5000 ,...
Starts easily, run for 5 to 20 minutes and then
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
Jul 26, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan generator 2005 model hgjab-1038c rv generator will not keep batterys charged have to hook battery charger every time that generator is not running what should i check for this genator is in my 2005...
Go to the auto parts store and buy a "Battery Tender" solar powered, or get an electric trickle charger. Or install a battery disconnect for the period the unit is not in use; you can disconnect the battery.
HTH,
Mike...
Dec 02, 2009 | Watts Onan Portable Generator - 5000 ,...
I just bought a 1999 Winnebago with an Onan 6500 genset. It only has 45 hours on it. It will run for 15 - 20 minutes with the AC on and then quits. It will restart after a few minutes and go through the...
a 10 year old genset with only 45hrs on it...sound like the carb may need replace. working with these rv units for 6+ years has taught me that you cannot clean one well enough to fix it. you will need a new carb. your local onan dealer can help. when new the warrenty makes known that 1hr per month under load will keep the carb clean and problem free. evaporating gas leaves deposits and eventualy plug fuel jets. no replacement parts are recommended. i've personaly worked on rv's with 200+ hous and no issues at all. hope this helps, good luck...
Jul 12, 2009 | Watts Onan Portable Generator - 5000 ,...
VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Apr 05, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
168 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
