My split system have a horrible smell that comes out from them, i have cleaned the filters and the smell wont go
    Scholar:
  • 149 Answers
Probably have to have the coils or the evaporator section cleaned up. the smell can be mildew accumulation.You have to check the coils probably some mildew there.
Posted on Apr 21, 2008
A horrible sickly sweet smelling odor blowing out back of refrigerator
would check ur drain lines for food residue that rotted u may need to defrost and clean the drain line in freezer and fridge
Jun 22, 2015 | LG Refrigerators
My dryer had a horrible smell when in use, had the lint filter cleaned by a repair man and now it throws it's breaker when not in use. What is going on?
The repair man should have done a safety check. Call a different one. Clean your filter after each load.
Nov 22, 2013 | Hammering
I'm getting a horrible sour/sweaty like smell blowing out of my Henry when vacuuming, i've tried to clean the filter, but its still just the same & the smell also seems to be in the head o
You can buy little sachets of nice smelly stuff to put inside Henry. Most supermarkets have them. Makes the carpets smell nice too.
Feb 07, 2013 | Henry Vacuums
1988 honda accord dx stalls after starting when cold, when tring to restart smells like fuel and wont start
check if the air intake is clear , no cracks/split etc in the pipe work , air filter is clean,if look ok then i'd get the stepper motor checked out as a first step
Jun 11, 2017 | Honda Accord Cars & Trucks
THERE IS A HORRIBLE SMELL - LIKE DRAINS COMING FROM MY WASHING MACHINE - DURING THE WASH ASWELL AS WHEN NOT IN USE - ANY IDEAS? I HAVE CLEANED AND EMPTIED THE FILTER
I would suggest checking the plumbing u-bend for trouble first.
If cooler washes are normally used they do not kill bacteria- that needs 90+ degrees. You could also run the contents of a proprietary washer cleaner/ de-scaler through the system which will also clean the heater element!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 01, 2011 | LG Washing Machines
Horrible, gym socks kinda smell coming out. how can i fix this?
Try cleaning the filter and you can buy some coil cleaner for the inside coil that doesn't have to be rinsed off. It is supposed to clean and deodorize. Might as well clean the outside coil while you are at it. You can also remove the unit from the window and take the case off to clean inside.
Aug 28, 2010 | Frigidaire FAC125P1A Window Air...
I have a front loader that smells like something died in it. I have tried affresh bleach Tide washer cleaner Basic G leaving the door open cleaning the gasket washing the drum cleaning the filter and hoses...
you can open the filter drainage under near the drain hose. there may be something that comes into the washer drum and died leaving a smell. how to open the filter is rotated and pulled out only. then you try to drain the washing machine how to turn it. will allow water or sewage, which is in the drum filter out of the hole. and do not forget to clean the exhaust filter the water, there will be a lot of dirt.
Jul 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The water from dispenser has horrible smell
what kind of supply line is gong to the unit,, if it is plastic change it to copper,, copper doesn't keep the sediments stuck to it, which will make it smell,,
Jul 15, 2008 | Whirlpool GD5SHAX Side by Side...
Heating & Cooling Logo
472 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
