Question about Friedrich Heating & Cooling
Our 8yr old 14,000 BTU Friedrich
Our 8yr old 12,000? BTU "window shaker" suddenly doesn't work. We turned it on and the temperature lights up, but the compressor doesn't go on. Never had trouble before. I plugged into another outlet, still nothing. Ideas?
  • 70 Answers
Check the stat or cap, but for the most part cheaper to replace it.
Posted on Jul 18, 2010
I working on a old Friedrich water source heat pump Model # V42 does anyone knows what size is it?
The friedrich name was taken off of units in the 80's when the climatemaster name was invented. My guess is 42000 btu or 3.5 tons rated capacity
Feb 05, 2015 | Friedrich Heating & Cooling
My braker keeps tripping with only the tv on and electronics that barely use a lot of juice. it doesn't seem like it pumping out enough cool air for 14,000 btu's either
14,000 btu is a very large unit it should be on a dedicated cuircut of either 15 or 20 amps all by itself.check the rating plate for correct amperage
Jul 21, 2011 | Soleus LX-140 Portable Air Conditioner
Purchase an friedrich 1400 btu last year from pc richards was working well until last night when I turned it on the light came on heard it humming and then it turn off my surge. What could be wrong with...
Take the surge supressor off the unit, or it better be a good one, and its best not to have it plugged into any thing, just straight into the plug in, and your unit is 14,000 btus
Jul 04, 2011 | Friedrich Heating & Cooling
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
The switch on my Friedrich Quietmaster panel is
you can find them at any A/C supply house for window unites or on line. try Sears
Jul 14, 2009 | Friedrich QuietMaster SL36L30 Air...
Heating & Cooling Logo
104 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
