Question about RTO Mini Quads
I have an apache 49cc quad it is running but when i open it up it just starts to die and lose power checked spark fine check carb really clean any ideas?????? much apprieciated!!
    Genius:
  • 1,970 Answers
Mcdevito75 here, Sounds like a vacumn leak check bse of carb, (Tighten) check any and all hoses comming off the carb. and at there destinations. It could also be a warped cyclinder head., specialyy with 2 cycle engines. Have a dealer or motorcycle shop check it out.
Posted on Jul 17, 2010
Apache quad
carb might be clogged clean it
Mar 21, 2014 | ATVs
Grizzly 350 wont fire
First check the fuses.check the start ,run switch,there should b some kind of protection for this..possibley a in line fuse??
Aug 07, 2012 | Yamaha Grizzly 350 4x4 07 Airbox Air Box
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Apache quad 100cc Bike will not start, battery is ok, plenty of petrol in it but will not fire, can anyone help,
this typically comes down to basics. you engine needs air,fuel and spark to run. FUEL - pull the main fuel hose in to the carb from gas tank and turn on to be sure fuel is getting to the carb. SPARK - next pull out spark plug and while still connected to igntion cap, touch end of plug to motor and turn over engine. if you do not see spark, this is your issue and is usually the most common issue. if spark is present, spray starting fluid into the spark plug hole, reinstall plug and try to start, if it trys to start as in starts then dies, your not getting fuel past or from your carb. Clean carb. AIR - last but not least check your air filter and insure it is not clogged or obstructed and is allowing air to the engine. As for no spark, the can be many issues from a bad CDI ignition coil or generator/stator to just a bad kill switch or cut/unplugged wire.
Dec 14, 2010 | ATK 125 2-stroke Motorcycles
Apache rlx300 wont start spitting back through carb
check spark,timing from side case side,then swap spark plug,try to bypass spark cap,then check flow of petrol to carb,clean carb and allow to cool if needed.Sometimes a coil just dies for no apparent reason..The last resort is to swap the coil inside the side case...
Jul 26, 2009 | 2004 Factory bike Chrono SM 250
49cc 4 wheeler
check fuel delivery & filter
check for dirty & or loose or boken coil wires
these coils are a problem on these little guys!
very cheap to replace though!
Jul 19, 2009 | RTO Mini Quads
RTO Mini Quads Logo
670 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
