Question about Dishwashers
Dishwasher can not change the program on the door panel. also, the dishwasher is not getting the dishes clean.
  • Heather Joy Apr 24, 2008
    Hello i have a ADP 8540 and the start button is just flashing at me.. won't start at all..
    PLEASE HELP ME !!!
    Regards
    Heather
    Genius:
  • 1,073 Answers
Is there a door lock button on the control
Posted on Apr 22, 2008
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Having trouble with dishwasher- I feel like dishes are not getting clean- will replacing circuit board on dishwasher help dishing become cleaner?
You may need to clean out the filters that keep food from being pumped up to spray out of the sprayers. This will depend on your make and model as to how to do this. Clogged filters will reduce the amount of water being sprayed. Try opening the door mid cycle to see if there is a vigorous spraying action. If the water being sprayed is underwhelming, it may be clogged filters.
Feb 13, 2013 | Maytag Dishwashers
Control panel or electrical panel not working right. It stops washing at 10 minutes
The DD603 dishwasher from Fisher and Paykel is a very sofisticated electronically controlled dishwasher. It does not have a control panel or electrical panel unlike some of the other brands of dishwasher which are electromechanical controlled.
So if it is stopping with 10 minutes left on the LCD display, then it might have simply gone into the Dry mode. A small fan in the door unit starts up and sends warm air into the unit. At this time the dishwasher gives a couple of beeps. You will have to wait until the time display goes to 00 provided the dishwahser is set to be in the Clean Dish indicator option is on. This means the washing is complete. Refer your instruction manual.
It is also a good practice to keep the area around thw wash program button (on the drawer door top edge) clean. Sometime grime can cause false trips.
Hope things are not as bad as it may appear.
Nov 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishes are not getting clean
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Jul 16, 2009 | Dishwashers
LG Dishwasher redepositing debris back onto dishes
Have had a problem with our LG 5811 Dishwasher not operating.
I have found the Vent Hole Cover located inside the Door was not installed correctly. I used plumber putty between the plastic fitting and the inside face of the Door and turned the Cover fully to lock in place (vent hole is toward Door bottom). Water was leaking previously from this opening over the wires in the door.
Another problem was the lower Door Seal (under the Door) it was not installed correctly either. It was actually too long and would not seal against the bottom of the inclosure. Water was coming out and spraying the wires in the door. I had to remove the metal stiffener over the front of the Dishwasher to get to the Door Seal. I removed one end and reinstalled the seal. The Seal laid flat but was approximately 3/16" to long. I cut off the end with a sharp knife - seems to be the correct length now.
May 23, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Indesit D63 dishwasher dishes not getting clean
check that the arms top and bottom turn freely and are not blocked.also if you use tablets,then you do not need to use rinse aid in the door,the coating could be due to over rinse aid as the tablets have this in,if these are ok you may benifit from putting a good quality cleaner through if
May 05, 2009 | Indesit 24 in. D63 Free-standing...
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
LG dishwasher wont clean top rack dishes
If the unit is cleaning the bottom dishes normally, try unplugging the unit for 5 minutes to reset the control board.  If that doesn't work, then the control board needs to be replaced.  The problem is that control board is not diverting the water to the upper wash arm during the cycle.  Possibly a program problem
May 30, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Soap door doesn't open
remove the door panel and replace the wax motor on the dispencer
May 22, 2008 | Whirlpool 24 in. DP840D Free-standing...
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
242 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
