Question about Garden
I cannot tighten my tooless husqvarna 235 e series chain. Ive tried but it just doesnt seem to tighten. Any ideas for me or manual to look at, maybe Im doing it wrong.
  • 211 Answers
SOURCE: cant find the screw to tighten chain on saw
Hi
You have to look from profile to the chain saw(clean it)
best regards savumihai71
Posted on Dec 10, 2008
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
  • 360 Answers
SOURCE: I can't get the clutch cover back on my Husqvarna
The chain brake is engaged when the brake handle is moved forward.....to ensure it is actually the chain brake...with the clutch cover off and in your hand, pull the chain brake back...if it will not move, attempt to move it forward to see if it was not engaged...if it moves forward, it is now engaged...pull back to disengage it...a lot of times the problem is not the brake, but rather the bar adjuster....if the brake is not the problem,...loosen the bar adjuster and reassemble the unit...once assembled, then adjust the bar as per the user manual.
let me know what you find.
clarkco
Posted on Apr 30, 2009
SOURCE: Chainsaw Service manual for Husqvarna in New Zealand
Free download on:
http://lawnandgarden.owneriq.net/ex/thread/view/idThread/278287
Posted on May 15, 2009
  • 76 Answers
SOURCE: husqvarna 235 oil not getting to chain
try using thinner oil
Posted on Jul 16, 2009
I need to know the correct fuel ratio for a Huska Vona 235 chainsaw
50:1. Your manual is here.
[PDF]OM, 235 e/ 240 e, 2008-02, Chain Saw - Husqvarna www.husqvarna.com/.../HUSO%2FHUSO2008_USen%2FHUSO2008_USen_O08020...
  1. Cached
235e 240e. Operator's manual .... You will find the following labels on your chain saw: ..... recommended (a lean mixture may mean that the fuel lasts longer than ...
http://www.husqvarna.com%2Fddocdownload%2FHUSO%252FHUSO2008_USen%252FHUSO2008_USen_O0802031_.pdf&usg=AFQjCNHmUdP3dUYTbfqmTs7Z7SATwGd1Nw
Jan 23, 2017 | Garden
How do you tighten the chain
There are a number of different adjuster types, manual and tooless, manual adjusters will have a screw driver slotted head screw either on the front of the saw or at the side, slacken off the bar nut/nuts turn the screw clockwise to increase the chain tention, tooless adjusters will have a large plastic nut with a fold out wing to aid removeal, slacken this off there will then be a thumb wheel to turn which will adjust the chain.
Jun 23, 2012 | Poulan 14" Chainsaw
What is the longest bar &chain i can put on my husqvarna 235
if you tighten the panel for the bar and chain too tight it pulls the bolts out slightly out of the chassis of the body. that is why it isnt oiling properly. i had a 235 and that is what happened to mine. what you could do is file down the raised plastic where the bolts enter the body and that might help.
Apr 17, 2012 | Husqvarna Garden
Loosen or tighten chain on a 445 Husqurna Rancher chain saw
If this is the tooless system, flip open the wing on the bar cover securing nut, slacken off one turn, now use the knurled wheel in the cove to slacken, or tighten the chain, if it has two 13mm bar nuts, slacken them off one turn each, then use a flat blade screw driver through the side cover, betwwen the bar nuts to adjust the chain, the screw is quite small so clean away the saw dust to locate it.
Oct 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you put the chain back on the track of a Husqvqrna e series 235 chain saw.
You need to make sure the blade is not damaged. You need to release the chain tension screw, most cases; you turn in counter clock wise to release the tension rod. Do it in the reverse when you reinstall chain to tighten it back up to operating conditions.
Aug 25, 2011 | Husqvarna 450 e-series 18" Chain Saw
Chain tension screw broken
The chain tension screw is housed in the side/chainbrake cover, the tooless version is also here, remove the cover securing nut/nuts the adjuster screw is then housed under a cover held with a single screw, once the cover is removed the threaded screw can be taken out and replaced, the tooless adjuster comes as a kit part no. 537392901, and for the non tooless 537286501, this is just the screw.
Jun 29, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I can't get a replacement chain back on the bar on
The 450E is a tooless system, make sure the brake is off by pulling the handgurd fully back to the top handle, flip up the lever on the big grey fixing nut, undo counter clockwise, wind the grey knurled adjuster wheel facing out of the cover fully back, remove the chainbrake side cover, push the guide bar fully back toward the sprocket, you now have enough rome to replace the chain onto the guide bar rails, now re fit the side cover, make sure the adjuster pawl in the cove aligns with the adjuster hole in the bar, re fit the big fixing nut finger tight, wind the adjuster wheel down to re tention the chain, when the chain is snug all the way around the bar tighten the nut fully.
May 29, 2011 | Husqvarna 450 e-series 18" Chain Saw
How do you set the chain tension on a 345e?
The E version is tooless, so flip out the wing in the centre of the big cover fixing nut,slacken the nut off half a turn, now turn the knurled adjuster in the side cover, down to tighten, up to slacken, there are many schools of thought about the correct tention of the chain, but basically the chain should sit snuggly all round the guide bar, and with a gloved hand pull manually around the bar with out too much force, it should never sag on the bottom of the guide bar.
Apr 27, 2011 | Husqvarna Chain Saw 20" Bar
How do I remove the chain on a Husqvarna 455 Rancher chain saw
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, remove the bar nuts ( 13mm ) if it has tooless chain adjustment flip the nut wing out and undo the big grey nut, screw the chain adjuster fully back, if tooless wind the knurled adjuster fully back, now remove the side cover/brake assembly, loop the chain off the nose of the bar, and then over the sprocket and remove.
Apr 15, 2011 | Husqvarna Garden
I can't get the clutch cover back on my Husqvarna 235 e because the chain break is engaged. Spring is too tight to disengage it.
clarkco
Apr 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
