Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Have a model 9200 that is not dispensing fluid,
Have a Bissell model 9200 that is not dispensing fluid, wondering which part is the pump that controls water, I see a blue item inside that appears to be connected to the tubes that select water spray. Also noticed when depressing hand tool spray attachment that no water is dispensed. Strongly suspect the water pump but do not know which item is that pump. Have assured Bissell cleaner solution is present.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bnv,nm
Posted on Sep 30, 2010
  • gracejulia Apr 24, 2011
    My rug cleaner was leaving streaks but I didn't know how to take it apart to see what was wrong. I read the technical services page and once I knew how to take the plastic front off I cleaned it and it fixed my problem. Thank you very much.
  • D. Floyd Kolb
    D. Floyd Kolb Apr 25, 2011
    Great!! Glad it helped you!!
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
Bissell proheat 9200 won't dispense water
Check your filters. Your User's Guide should provide you with location info. Contact Consumer Care at 1-800-237-7691
Jul 17, 2014 | Bissell 2X Proheat 9200 rug cleaner
My 6 month old bissell 9200 upright will not dispense water and solution.
heatman101
Sep 20, 2010 | Bissell 9200 Upright Vacuum
My bissell Proheat 2X Carpet cleaner will not dispense water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Apr 25, 2010 | Bissell 9200 Upright Vacuum
I have bissell proheat 2x 9200 no water or cleaning solution is dispensing from bottom of machine hand dispenser is not working too. how can I troubleshoot it?
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Jan 21, 2010 | Bissell 9200 Upright Vacuum
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
1,133 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
