Question about Fujitsu fi-5120C
We are not able to get our Fujitsu fi-5120C out of status 8. We've turned it on/off unplugged it changed one of the pads (as it was bent). We left it alone for a day and it's still not working. Do you have any suggestions on how to troubleshoote this?
    Novelist:
  • 104 Answers
Thank you for contacting FixYa.
Please clarify if the error is E8 or some different error. E8 error indicates that SCSI fuse is blown. When 5V, 3.3V fuse is blown, the scanner does not turn on and E8 error is displayed. Check the SCSI fuse status. The SCSI fuse is located in the Control PCA marked as TH2. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable. #Check the SCSI cable status.
- Other SCSI device malfunction. #Check the SCSI device.
1. Does the same symptom occur after turning OFF and ON the scanner?
To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check if the SCSI cable or other SCSI devices connected to the scanner cause this error. The scanner can work even after this error occurs. However, to remove this error you may have to replace the Control PCA.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Microsoft Word - P1PA03289-B30X6_03.doc matsubara 11.9999 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Posted on Jul 27, 2010
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
Fi 5120c scanner - Vertical Line left of Center
It is the GLASS. Line up your paper to see where the lines came from (check front side and back side). Open the scanner by pushing the Blue Button on the right. Look for the glasses at the bottom of the scanner at the spots making the lines. Clean it and re-scan.
Oct 11, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
Sep 04, 2011 | Fujitsu fi-5120C
Is a brake roller the same as a pick roller?
Hi Tracy,
The brake roller is diffrent from the pick roller in all models. However, in Fujitsu fi-5120c, there is no brake roller, only Pad Assy and Pick roller are present.
Thanks,
TechSatya
Aug 24, 2011 | Fujitsu fi-5120C
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
How to remove Assembly pad message after replacement
you can reset this message in the scanner controll panel.
Please call windows <start>
<settings>
<system control>
<scanner and cameras>
open <scanner and cameras>
inside you will find your fujitsu scanner fi-5120C
now call <attributes>
-- in WIN2000 there is a button, in XP use the right mouse button--
in <device settings> you see the ADF counter, an the consumable counters for pad and pick roller.
Reset the changed parts, confirm the EEPROM writing
and the message will be cleared.
Jun 24, 2008 | Fujitsu fi-5120C
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
May 29, 2008 | Fujitsu fi-5120C
Fujitsu 5120C Scanner
http://193.128.183.41/home/v3__product.asp?pid=462&inf=doc&wg=75
Dec 12, 2007 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
818 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
