Question about Microsoft Picture It! Publishing Platinum 2002 for PC
This program loads but won't run on windows 7
    President:
  • 2,571 Answers
Google to see if there are any updates, but i think its time to get new software
Posted on Jul 17, 2010
I have a Samsung NP-RF511 S04AU That won't start past the startup screen. I don't want to lose what is on my C drive can someone please help. I am running Window 7
Several things you can try.
Roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
In Safe Mode try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
Tip
Troubleshooting 101
Fix common PC problems Having trouble with your computer? You've come to the right place. Even if you don't know a computer language (or want to), you can solve several common PC problems on your own.
F1 is magic: Get help on your PCtroubleshoot.jpgIf you can’t figure out how to complete a particular task in your software program—and you’re using a PC—the most important shortcut to know is the F1 key. Just push it while the program—Word, Excel, or whichever program you’re using—is open and active, wait a moment, and the Help window specific to your active program will appear. The F1 key works with almost all Microsoft products, so it’s a helpful starting point for a wide variety of problems.
In this article, we offer many ways to do what you need to do in Windows 7 and Windows Vista. Often, there may not be a Help topic for Windows XP, but the process is often the same as in Windows 7 or Windows Vista. The only difference is usually where to find the link in Control Panel. Most often, it’s just a matter of slightly different wording in the heading or the text describing the task. Don’t worry. If you search in Control Panel, you’ll usually find the link you need.
The basicsIf you’re encountering a different kind of obstacle – your new device won’t appear on your desktop, an application you added won’t run, or your computer is refusing to start up – here are a couple of preliminary steps:
  1. Before adding any major hardware or software to your system, make sure you've recently backed up your Windows 7-based PC or your Windows Vista-based PC as a safeguard. By using the automatic backup functions, you can schedule regular upkeep for maximum convenience.
  2. Write down the contact information for Microsoft Customer Service and Support, should you need to consult an expert. Take a second to print the below instructions as well, and keep them handy as you walk through the troubleshooting process.
  3. Many issues can be resolved by simply checking to be sure that all of your plugs are connected properly. After you are sure of that, try restarting (“rebooting”) your system. Turn your computer off, and then back on a few seconds later. If the problem continues, follow the steps below.
Locating the problem Ask yourself if the problem is related to hardware, software, or the operating system (such as Windows 7, Windows XP, or Windows Vista). The following are some common indicators that can help you decide which is the right answer.
If you're uncertain, don't worry. Just start at the top by determining if your software is working, using the Software errors section that follows. If the issue persists, proceed to the Hardware trouble section and then to the System failure section.
You can also find really helpful information at Microsoft Help and Support. If you'd like to search by individual program, try the Product Solution Center. Or check the columns and blogs found on the Windows Community Web site, where you can find helpful input from experts and fellow computer users.
The lists on the right side of this page may also help you narrow down the type of trouble you are experiencing.
Software errorsIf programs refuse to install, won't appear on your desktop, can't seem to run without freezing, don't load at a decent speed or function properly, or Internet access is unavailable, here's how to troubleshoot:
General issues
  1. Confirm that your PC meets the software's minimum system requirements. If it doesn't, you'll be unable to run the program without upgrading your computer's hardware. Note that PCs which barely meet or just slightly exceed these minimums may run the software more slowly and can be less reliable. Windows 7 and Windows Vista users can reference the Windows Experience Index to quickly gauge their PC's general capabilities.
  2. Check for compatibility with Windows 7 and Windows Vista.
  3. Close open programs and windows that you're not currently using. These can eat up system memory and processing power, slowing your PC or preventing additional software from running. Try running the program again.
  4. Check available hard drive space. Roughly 5 to 10 percent of your hard drive's total storage allotment should be left free to ensure optimum system performance in Windows 7 and Windows Vista, prevent crashes, and keep Windows running at top speed.
    Note Use Disk Cleanup to free more space:
    Windows 7
    Windows Vista
    Windows XP
    Check for program updates and information on frequently encountered issues at the software manufacturer's Web site. For Microsoft products, you can also load Windows Update for Windows 7, Windows Update for Windows Vista, or visit the Microsoft Download Center. If you install an update, restart your computer, and attempt to run the program again.
  5. Uninstall or delete unwanted programs in Windows 7 or Windows Vista to cut down on clutter and remove any drain on your system's resources.
  6. Disable programs you don't use to in Windows 7 or Windows Vista by preventing them from automatically loading when Windows starts. If you’re running Windows 7, restart your computer, and try the program again.
  7. Defragment your hard drive in Windows 7 or Windows Vista to improve performance.
  8. Scan for viruses and spyware. Windows Defender in Windows 7 and Windows Vista can help detect and prevent threats, along with preventing annoying pop-up notices and unauthorized home network intrusions. You can scan your PC for free.
  9. Reboot your computer and try loading the program again. If it still won't load or work correctly, you may need to uninstall the software and then reinstall it from scratch and reboot again. Advanced users can also try these advanced troubleshooting tricks in Windows 7 and Windows Vista.
  10. Consult Microsoft Help and Support and the Windows Community. If live assistance is required, first contact the software manufacturer's customer support department. For additional assistance, try Microsoft Customer Service and Support.
on Jan 17, 2010 | Computers & Internet
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
I have windows 7 bought stilllife2 from walmart it loads however can not get into my inventory? help
Trisha,how are u trying to access the inventory? Did you try right click already,that's how I got into mine
Jul 03, 2012 | Microids Still Life for Windows
When I try to install the program, it says that I may to use a 32-bit system. I have Windows 7, 64-bit. Does this mean that the game won't work on my computer?
Maybe so. As alot of programs and software still recognizes windows xp and not windows 7. I have encountered alot of similar problems with windows 7 and the same program runs well with windows xp.
thanks,
G.
Jun 27, 2011 | The Learning Company Arthur's Thinking...
Program won't run in Windows 7
That program is very old; they're on version 20 or something like that, and may not be able to run on Win7 at all. (You really should just get an updated version. (v.15 is only $5-6))
The only chance of getting that app working under Win 7 would be to run the program with "compatibility mode" set to Windows XP... Or maybe even Windows 98 or 95 for something that old.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Jun 27, 2011 | The Learning Company Mavis Beacon Teaches...
I recently got a computer with Win 7, and everytime I try to use my Eurotalk Hawaiian, The program won't work, It loads but it won't play the games or the word reviews. How do I fix this?
This might be due to software compatibility issues with Win 7.
Try running the program in "Windows 7 Compatibility Mode", there are not assurance it will work. Hope it work for you & good luck.
Here are help available at these link below:-
1. http://www.sevenforums.com/tutorials/316-compatibility-mode.html
2. http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Hope it helps.
May 29, 2011 | Eurotalk Computers & Internet
Sybase Powerdesigner 9.5 Windows 7
PowerDesigner 9.5 wil load on Windows 7 but it won't run. I was able to get it to run by installing it in the virtual XP environment on Windws 7.
For this to work,
Must be running Windows 7 Professional or better, and
Your machine has to allow virtual machines (BIOS Setting).
You will need to download 'XP Mode' and indows Virtual PC' from Microsoft.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You will be able to run PowerDesigner 9.5 and oter applications that will not run in the Windows 7 environment but ran previously in the XP environment.
Mar 15, 2010 | Sybase Powerdesigner 9.5 (20330-01-0950)
Webroot 6.1 will not load on Windows 7
Are you running another antivirus program at the same time?
this will cause it to hang, maybe reinstall the program (repair) and see if this helps
Nov 13, 2009 | Computers & Internet
Microsoft Picture It! Publishing Platinum 2002 for PC Logo
166 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
