Question about Brother MFC 420CN All-In-One InkJet Printer
I just replace my ink cartidges (all four colors) but, no ink apears on the paper once printing has been completed.
  • altreciawhit Jul 17, 2010
    The reason that my printer isn't working made since. However, the solution was not helpful.
  • 857 Answers
When you filled your cartridges were they empty? If so there is a good possibility that the nozzles are gummed and dried up.
If you are going to fill them yourself watch the indicator that comes up on the screen it will tell you when you are getting low. If you get a low indication fill it asap. This will keep your nozzles wet and free flowing. Waiting until its empty can cause them to gum up and altimately dry out.
My solution is to go to the store buy brand new cartridges. Go through the the full set up that your manufacture recomends. This means using the install new ink cartridge utility that came with your printer. Print a test page and print a nozzle aligment page.
Just remember never let your ink completely run out before filling. If you follow this you will never run into this problem again.
Posted on Jul 17, 2010
    Thanks very much fo your assistance. How to I solve this problem if I no longer have the ink cartridge utiltiy or hand boonk that came along with my printer?
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Photos come out totally blurred with colors mixed. Happens on all sizes of paper (photo quality).
  1. Make sure that there is letter, A4, or legal unused plain white paper in the input tray.
  2. Touch Setup on the display.
  3. Touch Tools .
  4. Touch Self-Test Report . A self-test report prints. Figure 1: Self Test Diagnostic Pagec01154260.png
  5. In the Print Quality Pattern section on the test page, look at the color blocks for any lines. Figure 2: Print Quality Patternc01154261.png
  6. If there is no color bleeding in the Print Quality Pattern color blocks, print a document to determine if the issue has been resolved.
If you have completed all of these steps and are still experiencing a problem, continue to Step three. Step three: Check the paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
If you have completed all of these steps and are still experiencing a problem, continue to Step four. Step four: Check the printer settings
  1. In the software program you are trying to print from, click File and then click Print . The Print window opens.
  2. Make sure that your printer is selected and then click Preferences . The printer Preferences window opens.
  3. Click the Printing Shortcuts tab.
  4. The Printing Shortcuts tab lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab:
    • General Everyday Printing
    • Photo Printing-Borderless
    • Photo Printing-With White Borders
    • Fast/Economical printing
    • Presentation printing
    • Two-sided (Duplex) Printing
    NOTE: These general printing shortcuts have pre-selected settings.
  5. To change the settings from the ones that are available on the Printing Shortcuts tab, click the Features or Color tab. Options on the Features or Color tab include:
    • Print quality : If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches your paper type exactly, select it rather than Automatic.
    • Paper size : Make sure this matches your paper.
    • Print in Grayscale : Print a document in shades of gray.
    • Orientation : Specify how the document is positioned on the page.
    • Paper Source : Select the tray that you want to use for printing.
    • Two sided printing : Print on both sides of the paper.
    • Color Management : Specify the color space that the printer will use to interpret image data.
    • Pages per Sheet : Specify the number of pages of the document to print on each sheet.
If you have completed all of these steps and are still experiencing a problem, continue to Step five. Step five: Clean the printhead
NOTE: Do not clean the printhead unnecessarily because this wastes ink and shortens the life of the ink nozzles on the printhead.
  1. Make sure that there is plain white paper in the input tray.
  3. Touch Tools .
  4. Touch Clean Printhead . The HP All-in-One cleans the printhead and prints a test page.
Step six: Service your productIf you have completed all the steps listed above and are still experiencing a problem, service the product
Dec 07, 2010 | HP Photosmart C8180 All-in-One InkJet...
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Brother 350c
First printing a photo takes lots of ink , it depends on the color of the photo , cyan is blue which maybe consumed more in the printing or there changes that the ink may have dried in the cart hence your getting this error ,remove cart take damp paper towel and hold the paper on the place where ink comes out gently for 20 second ,make it does not touch copper contact it may damage the cart ,make sure you check the place where ink with dry paper its usually bottom of the cart and repeat the above step with dry paper towel and try to print if you get the same error then you need to replace the cart or you can contact brother support and get cart replaced , once cart is used you need print once in week to keep cart from drying, you can use any photo paper which is compatible with printer .
Good luck....
Good luck....
Aug 24, 2008 | Brother Office Equipment & Supplies
Streaky pictures
hi, your head has damaged/need replacement. Try to clean it once again
thanks
Aug 15, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
Ink
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Sep 27, 2007 | Konica Minolta Magicolor 2530 DL Laser...
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
