Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer squeaks when it runs
After it warms up there is a squeak that sounds like it needs some lube. Where should I spray some WD-40?
  • Maytag Master
  • 3,361 Answers
Do Not Use oil.
Replace the drum rollers,clean the belt tension roller and the front drum glides.
Repeat...No Oil.
Posted on Jul 17, 2010
Why is there a squeaking noise when opening or closing door?
You need to lubricate the hinge pins, you can simply spray them with WD-40 or any other spray lube.
Jul 13, 2014 | Maytag M1TXEGMyB Top Freezer Refrigerator
Dryer making squeaking noise, what causes this?
The squeaking could be coming from the idler pulley on the motor, the drum rollers or a worn drum seal. It is not a good idea to spray the rollers with WD-40. The WD-40 will attract lint that will build up and could catch on fire inside the dryer cabinet. A bad drum support roller or any other squeaking component inside a dryer cabinet will normally need to be replaced.
Aug 29, 2011 | Maytag Neptune MDE6700A Electric Dryer
Our 600 Kenmore Gas Dryer, makes a squeaking sound and the drum does not seem to turn freely!
Instructions Things You'll Need
  • Putty knife
  • Phillips head screwdriver
  • WD 40
tyn-hp.gifGet what you need for every
project at HomeDepot.com
    • 1 Disconnect the dryer from the wall outlet or the breaker/fuse box. Be sure that the dryer is disconnected before you continue.
    • 2 Raise the top of the dryer. You will do this by inserting a putty knife into the crack between the top and front panel. Push against the spring clips to release. There will be one clip on each side of the dryer. Once the top has been released you can disconnect the wires to the door switch located on the right side on the backside of the front panel.
    • 3 Using a Phillips head screwdriver remove screws holding the front panel to the side panels. Pull the front panel away and lift off the bottom clips to remove it completely.
    • 4 Remove the belt from the idler pulley. The idler is located behind the blower/motor unit. When the belt is free you can slide the belt to the back edge of the drum. Lift it straight up to disengage the rear bearing from cradle.
    • 5 Pull the drum out through the front of the cabinet. You will be able to see the drum support ball on the back of the drum and the cradle holding the ball.
    • 6 Apply a generous portion of supplied grease or spray WD 40 into the cradle. In almost all cases, this will resolve your squeak. Once you have greased the drum to your satisfaction, you can reassemble the dryer.
Read more: How to Fix a Drum Squeak on a Gas Dryer ' eHow.com http://www.ehow.com/how_4899504_fix-drum-squeak-gas-dryer.html#ixzz1PYDjwD8h
Lithium grease works best for this.
Jun 17, 2011 | Kenmore Dryers
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Jan 02, 2011 | Dryers
My 11 year old electric Ge dryer squeaks when running.
WD-40. (Water Displacement test number 40)
Most likely just humidity and splashing water finally got to the parts and create a bit of rust, corrosion, and wear. Squeaking is nothing to worry about. If it starts to squeal then you have a problem.
Mar 14, 2010 | GE Dryers
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Squeaking when running
Repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 21, 2010 | Dryers
Squeaky Visors while driving
hi put a tiny bit of vasaline on hinges :)
Dec 30, 2009 | 2006 Nissan Murano
Squeaking shocks and struts
replace wheel bearings
Dec 12, 2008 | 1992 Acura Legend
Maytag Neptune MDE5500AY Electric Dryer Logo
253 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
