Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Syncmaster 913v monitor
I get verrtical multi-colored lines and nothing else. The monitor adjustments don't work. I also plugged it into my laptop and get the same thing.
  • Larry Saint Apr 21, 2008
    I know the computer is OK because I hooked up an old monitor and it works fine. The logic board referred to must be on the monitor.
  • aylamarie Nov 08, 2008
    I've had my monitor for quite a while now and first had this problem when I got it. I don't remember what I did to fix it back then, but I recently restored my computer and the problem is back.
  • 180 Answers
Your logic board need repair.
Posted on Apr 21, 2008
My Samsung SyncMaster 913V (Black) 19 in. Flat Panel LCD Monitor, does not work correctly. Every time I reboot my computer the screen only works for a few seconds and after that it gets black and a...
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Apr 15, 2017 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
My screen suddenly goes black and nothing is visible anymore..and when i restart then too after sometime same happens
check the RAM of your computer... try to disconnect it to the motherboard and then wipe the color gold a piece of pencil eraser... then connect it again.. turn on your computer..
Aug 29, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung monitor syncmaster 913v
Either you messed badly with the system color profile management, or, more likely, the VGA cable is faulty or improperly seated. Try unhooking the PC end of the cable (and, if you got yourself a model with removable cable, also the monitor end), and hook them back again, seating the connectors gently but firmly and tightening the connectors' retainer screws.
Aug 24, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913V it's displaying red lines
Sometimes this happens when the pins on the vga connector are bent. You can either try to straighten them (very carefully with tweezers) - be sure to check both ends, or try a new cable.
Apr 06, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have a Samsung SyncMaster 913v Monitor - black streak forming
Plug your monitor into another computer, If the line persists, it is your monitor, you need a new one. If it does not, It is your Video card, you need a new one. But it is one of the other...
Feb 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v color problem
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Feb 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
194 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
