Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Removing carburator from yard master 158cc lawn mower
Lawn mower did not have air filter on it and i believe that the carburator is clogged
  • 126 Answers
SOURCE: gas pouring out of air filter
carb is gummed up from the old fuel turning to varnish and clogging the jets. while trying to start, its trying to inject fuel, but its clogged and taking the path of least resistance (coming out the air filter).
you'll need to drain the gas tank and remove the carb to clean it out. if unfamiliar or uncomfortable doing this, then take it to someone to do a carb cleaning.
Posted on Jan 31, 2009
vincob
  • 718 Answers
SOURCE: mower will not turn over
Are you sure there is no water in gas tank, are you sure you get spark with new plug? component cleaned include carb and its components inside and out? If it turns over and does not stay running maybe first bet, you have water in the gas, second there is some kind of blockage within the carb probably so small you would not believe that it could be a problem.
If you disconnect the hose from the carb and empty some gas into a clear jar of some sort you can see if you have water in the gas. You will see two levels in the jar if contaminated, a yellowish gasoline level and a clear bubbly level which would be be water. Gas separated by something else means your mower will not start! Should be all yellowish in color.
Posted on Sep 30, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
  • 149 Answers
SOURCE: New mower 158cc Briggs & Stratton engine April 2010
Um if its new take it back before you damage the govenor then its not warrenty!!
the springs are fine. the metal the the spring conects to on the throtle control sets the high speed. dont play with unless you know what your doing for every ones safety
Posted on Jul 02, 2010
  • 150 Answers
SOURCE: I have a briggs and
A champion cj 8 plug will work fine. As far as air filter it is probably a paper on, take the old one to a dealer or small engine repair shop and they can match it up for ya.
Posted on Oct 06, 2010
I have a poulan pro 550 series B&S 158cc push mower. it sounds like a moved the choke when I went under a bush, because its running at a lower rpm. However, I can't find a manual choke.
The first thing I would do is , look at the front of the mower. On your front right side is your air filter. Remove the air filter, I believe that coincidently your air filter got to the point where it couldn't breathe anymore, meaning clogged to the point of choking. You can tell by putting it up to sun light and looking through it. If it's very very dirty , it needs to be changed. Also if there is a choke, it would be just behind the air filter. If it blocked off the end of the carburater then the choke is on. If this is the case then follow the rod that moves the choke. Possibly it was bent when you went under the bush. I believe you will find that your problem lies with a dirty air filter.
Jun 14, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
Mowing a dry dusty yard- mower running very slowly- some dark smoke also- air filter clogged? thanks
Sounds like you have restricted the air from going into your carburator to the point the mower is just running. Change the filter and if is that dusty you to may want to put on a mask. Be careful. GOOD LUCK.
May 27, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I have a briggs and stratton 158cc yard machine mower. I need to replace the spark plug and the air filter but I dont know what kind or size of spark plug I need nor do I know anything about hte air...
Oct 06, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Starts after priming, but stalls imediately
The carbs main jet (float bowl bolt) may need to be removed and cleaned as it can get partially or completely clogged from old fuel and dried up fuel and contaminants.
Aug 13, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
I need to clean the carb as it will not start. How do I get to the carb on the yard marchine?
Remove the recoil /airducting housing and aircleaner, and you should be able to access the carburator,
Aug 12, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Jul 01, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Lawn mower keeps looseing revs, it will keep going back and forth from full revs to about half revs.
Dump out the old fuel, and with the air filter off spray the inside of the carburetor with carb cleaner
Mar 22, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
97 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
