Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
Dishwasher latch How do i disconnect the wires going to the switches on both sides of the handle? I tried pulling them apart but no luck . Do I need to pull harder? Squeeze the prongs and then squeeze?
  • Maytag Master
  • 3,361 Answers
Everything you want to know about your Maytag Dishwasher is in this Service Technicians Manual.
http://www.servicematters.com/maytag_library/docs/16021814.pdf
Posted on Jul 17, 2010
  • steve
    steve Jul 20, 2010
    If you copy and paste the pdf file in your browser,then go to section 5-23,you will find a detailed answer to your question.
Door latch
The safety latch needs adjustment or is loose or worn out if you open the door on door side top you would be able to feel the the safety switch with your finger click on and off it should click very easy if not replace it make sure Dw is off or disconnected.good luck
Oct 14, 2013 | GE Nautilus 24" Built-in Dishwasher
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
Amana ADB1200AWQ model dishwasher, built -in, bought replacement part for broken door lock handle. Any idea as to steps to replace it?
Just replace my door latch handle for the 4th time in 6 years. its very easy,,, you have the same as i do. latch and handle assembly i got from amana parts on the internet, # for part is W10130697. it is the same i think as a whirlpool part. call 877-827-5003 to order about 48 bucks. very easy to fix. Open dishwasher door and take out the tork screws ,you will see the latch with the 2 micro swithes on both sides, black on the right and white wires on the left. pull off the plugs , put the new door latch assembly in place and put the two plug bacl on micro switches, put back in all the tork scews and your set to go.... good luck... it is real easy.
Nov 22, 2011 | Amana 24 in. ADB1200AW Built-In Dishwasher
My dishwasher will not close. It appears that the handle will not latch on the metal fitting of the washer. When I push on the handle it doesn't seem to show any resistance. On any other latch you...
the handle is in the closed possition even when door is open,. you need to sepperate the door front from the door back........ just undo the few philips screws.....the inside of the door will pull apart... just prise the catch back to the open position...... rescrew the door....job done........
cheers
Mar 24, 2011 | Whirlpool Dishwasher Handle Mount 67006113
Have a maytag dishwasher MDB6600 AWQ -latch/handle broke - bought replacement but not sure how to install - can you help
Just did this myself .Need the right star screw driver to remove 11 screws holding the door inner liner
then you can access the handle latch assembly. You pull off the 2 wire connectors to the switchs that are part of the assembly. Slip connectors onto new assembly.Position the handle part thru the door and re attach inner liner. 2 of the inner liner top screws also hold the assembly in place.Unfortunely , this didn't solve my problem of the dishwasher not turning on.
Jan 06, 2011 | Maytag 24 in. MDB6600A Jetclean II...
I have 2004 saturn vue and the rear door latch on the passenger side will not latch shut. i have taken it apart and it looks like a small black box.where could i find a cheap one, or an easy solution to...
It sounds like the the linkage, actuator (power locks), or the mechanism has broken or become dislodged. On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Pull back the weather seal and you should see everything and hopefully see the cause.
Apr 07, 2010 | 2004 Saturn VUE
How do you safely replace the handle on this MDB7600A dishwasher
Easy job. You'll need a new "latch assembly". I found one at appliancepartspros.com for $18+ and $7 shipping. Part #W10130695. More $ elsewhere. Procedure: Remove torx head screws on 3 sides of the door, then pull the interior part of the door away from the exterior a few inches at the top of the door. The old latch assembly (and the broken handle, now separate) can now be accessed easily. There are two wire connectors press fit to the latch assembly switches. Use a screwdriver if necessary to pry them off the old assembly, which is probably corroded somewhat. Do this one at a time and replace on the corresponding terminals of the new latch assembly so the wires don't get switched (or else mark them before removal.) Reposition the latch assembly, push the two halves of the door back together and replace the screws. Done. I'll note that the latch is positioned but not secured by two pairs of thin plastic "fingers" molded into the back of the control panel. Three of four fingers had sheared off. I didn't feel like spending $70 to $130 for a new control panel so decided to try doing without. The latch is secured by the two center screws at the top of the door, so as long as those are tight it should be fine.
Jan 02, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
How do I disconnect the electrical wire plugs from the door handle in order to replace the handle? The plugs won't pull straight off and so I am wondering if there is any piece of equipment needed to...
first shut off the power to the dish washer. The plugs are just verry hard to pull off. You may brake the switch on the old handle but if you have the right new part it should have new switches on it. Just pull hard side to side wiggle off.
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Take apart honda accord drivers side door
inside the handle there is ONE screw covered by a piece of plastic. remove the plastic and then remove the screw. pull handle out and disconnect it from the door latch bar. replace in reverse
Sep 17, 2009 | 1997 Honda Accord
Back door wont open and window wont go down
The rear window has to be completely down in order to move the tailgate! You should be happy that your window is stuck up, unlike mine which is stuck all the way down! I have to completly take apart my tailgate!! If you want to try a trick to get the rear window down, my bronco has a rear window switch right next to the headlight knob, take the 2 purple wires on that window switch, and cross them, if your motor still works and if the wires are good, that should make the window go down!!! good luck, hope that helps!
Oct 05, 2008 | 1995 Ford Bronco
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
99 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
