Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I want to know where the oiler is on the husqvarna 141
Also where I can get a manuel for the above
    President:
  • 2,220 Answers
Bill if you indicated the model in your question it did not appear here. Without it we can only provide our best guess. Most Husqvarna oilers are mechanical pumps and are located behind the clutch (99/9% of clutches have a left hand thread, please verify before you attempt removal).
You can locate an OM and IPL (exploded parts list, useful for disassembly and part numbers) here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 18, 2010
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
Jan 08, 2015 | Husqvarna 36 41 50 51 55 136 141 154 254...
Hto remove crankshaft seals on a husqvarna 136 chainsaw
You will fully disassemble the engine as you must the cylinder from the crankcase. Husqvarna only sells the seals with the bearings they must be pressed on to the bearings. Since the 136 uses the same bearing set as the 141 you can order a set seals for the 141. In this the old seals must be pressed off first.
Here is a link to a site that sales the 141 seals.
Husqvarna oil seals set fits 36 136 141 142
Dec 21, 2014 | Husqvarna Garden
Husqvarna 350 oiler swap ?
Not as far as i know, ive checked both parts manuals and they both have two different part numbers which would suggest they are different.
Jul 13, 2014 | Husqvarna Garden
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
Husqvarna chainsaw blade not engaging
I cannot remember a 141LE, there was a 141 petrol machine, there was a 1400EL electric machine, please let me know weather it is electric or petrol.
Mar 06, 2012 | Husqvarna Garden
Chain oiler quit working
Your oiler is under the clutch, The IPL (exploded parts list) for your saw is the only detail for the oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly (You require a special tool for clutch removal. Please ensure the one I list is a suitable substitute):
HusqvarnaUSA.com
06 1500198
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
Lou
Apr 27, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 340 oiler not working
Hello again Rudy.
Please reply below (Add Comments) with the serial number of your saw then I can investigate a little further.
You can reply even when the question is closed. I am not certain how but I get email notification of your reply when done correctly. If equipped the oiler adjustment is below the crankshaft on the clutch side. Look up from the bottom. On the side of my 359 is an icon of a link of chain with a drop of oil above it. The oiler adjustment is aft of that and can only be seen from the bottom of the saw. The manual I saw said 3 position only with CCW (3 - 18 to 20" bar) most oil. Forcing it beyond the stops causes a lot of problems.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2007/HOUS2007_1150331-95.pdf
Page 36
Is your serial number is between 07 18##### and 08 17#####?
Page 5 item 1 shows location of the serial number. Not all newer saws have an adjustable oiler. Please reply below.
Lou
Dec 18, 2009 | Husqvarna Garden
Husqvarna 141 will not oil and when i had it serviced they replaced the oiler and it did not solve the problem.
Remove the chain and bar assembly. Start engine--should pump oil from oiler port where the bar fits on the engine side. If oil comes out, then possibly the bar-oiling passage in the bar itself is plugged with dirt or sawdust--blow clean with compressed air. If no oil comes out from the port, check the pickup tube inside the oil tank. Drain the oil into something and fish the pickup tube end out with a hooked wire. Replace if collapsed, cracked, or loose.
Jul 04, 2009 | Husqvarna Chain Saw 20" Bar
Chainsaw 141 oiler not working
Somehow you have ended up posting this question in the Sewing machine section, so I suggest you re-post under chainsaws or you will never get a response......I don't know about chainsaws myself I am afraid, but if you have a sewing issue, let me know !
www.bargainbox.com.au
Mar 22, 2008 | Sewing Machines
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
171 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
