Question about Nintendo Wii Console
Not turning on
My wi was made for a 120v electricity.i tried it on a 220v.it made a sound like a little explosion and then turned off.and now its not working anymore.what can i do?how can it be fixed?is the problem from the console or from its charger?if its from the console is it a big problem or just a fuse problem?
  • jemimay18 May 13, 2008
    I need help ASAP! My daughter just got her wii today and sad to say her uncle removed the transformer and now she put the plug ( we use 220volts) to a wrong voltage and a little explosion sound we hear. the wii is not working anymore. we tried to plug it with the transformer again a little blink of green light is appearing to the wii console but still did not work. what to do? is the console damage? i have no idea also how to replace the adapter or any other part coz there is no nintendo centre here in philippines. help pls.
  • arjaybgayani Sep 27, 2008
    guys have you solved the problems?? I have that problem to. . is there by anyway that you could help me too, if the real danger is in my adapter or my wii. . T_T
  • 53 Answers
Console problem you burnt the inner rader stelemen... have to replace it!! asap!!! man
Posted on Apr 26, 2008
I purchased remington shaver in US now it not working properly and not getting charged. where do i have repairing centre in hyderabad
Many Remington shavers sold in the US are only for use with 120V. Voltage in your country may be 220V-240V. If you attempted to use a 120V charger in your 220V electrical outlet without a voltage converter, you have probably damaged the charger.
Chargers can be purchased at shaveroutlet.com. You will need your shavers model number to select the correct cord. And, you may need to use a voltage converter if the replacement you get is for use with 120V
ShaverOutlet com ShaverOutlet com Cords Chargers Stands Shaver Replacement...
Feb 27, 2016 | Remington MS2-390 Electric Shaver
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
Where can I fix a circuit board in Spain or UK
I'm sorry but that sounds like a total loss. International power stanarf is 220v but US is only 120v. Likely all electronic circuitry is burned out. It would be cheaper to get it replaced since the board, motors and anything else electric will need to be replaced. Next tome get an international adapter that dials down 220v to 120v if you order anything else from US.
Apr 28, 2014 | KitchenAid KP26M1XPK - Professional 600...
120v plugged in 220v
It needs a new drive belt. Cheers john. Stylus City
Apr 02, 2014 | Crosley Audio Players & Recorders
What is the input - 120v or 240v?
Hello Seth Kwao - If you are referring to a gas range it is recommended to use a receptacle of 120v and a receptacle of 220v for an electric range.
Sep 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do i convert motor from 120v to 220v
you should have a label on the pump that shows the connections. 120V=low voltage 220V=high voltage. Here is an example of a label:
Conect the internal motor wires to the terminals indicated. Then connect your line to the terminals indicated
Jul 19, 2010 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
The cooktop will not turn on. The little red light in the lower right corner of the touch panel is blinking. If one touches and holds it it does not turn on a burner per usual. The timer function works....
I'm going to assume this is a new installation, either way, it sounds as if you're only getting one leg of your 220v circuit, which wld run the timer and lights but not enough to power the burners. This is prly not something you shld try and repair yourself as a 220v circuit can cause some serious damage. At the least, you could first, TURN OFF THE BREAKER and then check the connections to the cooktop to make sure all connections are secure.
Jun 11, 2010 | Gaggenau CK 171 28 in. Electric Cooktop
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
