On an ancient, Magnavox RD 0946 T102 TV (circa July 1996), is the TV's VHF/UHF co-axial cable needed for an exclusive connection to a VCR?
    Master:
  • 518 Answers
Not if the TV set has Audio/Video inputs on the back and a working remote that will let you switch inputs.
Geno
Posted on Apr 21, 2008
Magnavox converter box. How can I tell if the box is the problem or the TV? I have no picture, but it isn't the picture tube.
I assume that you are attempting to use the Magnavox converter box to convert digital TV signals received by your antenna system into analog signals for use on an older analog (non-digital) TV set. If that is the case then your first step at troubleshooting the problem should be to view the Magnavox installation instructions to ensure that the converter, antenna, and TV are all properly connected.
http://transition.fcc.gov/cgb/consumerfacts/setup-converterbox.pdf
Feb 23, 2015 | Audio Players & Recorders
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
Where can I get a manual for Magnavox TV Model # RD 0946 T102. Can You please tell me where to get one?
I think you may have gotten the model number wrong........It should be 2 numbers, 2 letters, 3 numbers, then 1 more letter........example: 32MD304V You might try a combo of the numbers you have, that might work...if not, will have to call customer support at 866-341-3738. Also, see attached for an image of example on how to find the model #. Hope this helps! 25321135-xkjoijzdmsbzgyxlspgmc3vi-5-0.gif http://www.magnavox.com/support/download_list.php?model=0946T102
Dec 14, 2014 | Magnavox Televison & Video
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I want to record a TV program and can't figure out how to do it. I have a Fisher HVD-805 model VCR player and a Sylvania HD TV. I have checked the plugs, cables etc and they are ok.
You must also connect antenna/cable to your VCR antenna/cable input, and then tune the desired channel at VCR and start recording, if your TV has video and audio outputs you can use them too, just connect them to line inputs of VCR, select them and start recording, this is more convenient when your VCR has only VHF/UHF but no cable channels tuner.
Feb 20, 2011 | Fisher Televison & Video
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
I have my cable coax connected to the UHF, VHF, CATV input. If I connect cable to Digital Antenna In input and do channel search will I receive local digiatal broadcasts or do I need to split the coax to...
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Jul 25, 2017 | Sanyo HT27546 TV
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
Top Televison & Video Experts
