Question about Toys
I have purchased 2 Lionel engines,2025 & 2026 that have bad paint chips on engine.Is it better to leave like they are or can I strip engine paint and repaint them. Will this cause them to lose there value?
    Genius:
  • 1,970 Answers
Mcdevito75 here, Chances are if you paint them, they will loose value. Best Bet, check with an antuque shop in your area, or online at antique restore.com Hope this helps.
Posted on Jul 17, 2010
Is there a factory warranty on paint for a vehicle past the bumper to bumper warranty?
call and ask gm but I would say no- sounds like contaminated primer - if you have time, you can strip and do yourself- brake fluid will easily strip paint- rent booth and shoot it- keep smiling- its only cosmetic
Jan 03, 2015 | Cars & Trucks
Starter gear strips after a couple times of starting on a 20hp briggs&stratton engine on a Murray lawnmower
bad compression release valve do a valve job and put in new valves or crank bearings bad do short block better just by new engine save the head ach with the motor valve job 100.00 per cylinder short block 300.00 or 400.00 plus 150.00 to put to gether best buy new tractor
Sep 11, 2014 | Murray Garden
Lionel 6-30218 not working,The engine is making hissing sound the headlight bulb is glowing the cab cars have light ,The remote Red Light is glowing when turnig the knob of throttle to right & lef
Your best option is to contact Lionel Customer service:
598-949-4100 ext. 2
9AM - 5PM Eastern Time Zone
They will give you instructions if they think it needs to be sent in for repair.
Jun 02, 2014 | Lionel A Christmas Story Gauge Train Set...
How to replace the front light on a lione santa fe train engine
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
Mar 14, 2014 | Lionel Santa Fe Diesel Locomotive Engine...
Bought a Lionel blue comet, Have legacy, put engine in program mode but engine will not accept engine I'd, what is wrong
You may need to have a chip upgrade done to your Legacy controler, especially if it is one of the earlier ones. Go to Lionel.com for instructions on how to determine if you need the upgrade. If this problem was identified for the Blue Comet then you should be able to find the solution listed on the Lionel site. If all else fails, e-mail them a description of the problem. Lionel provides great customer service.
Feb 13, 2014 | Crafts & Hobbies
2009 Ford Mustang GT/CS; Wiper's inop. Motor and switch are brand new. Circuit 2026 (constant 12v+) is good, circuit 2025 (ign 12v+) has no power. Fuses for both circuits are good, and I have 12v+ positive...
Could it go through a body control module some where? In most cases Key,to switch,then to motor. All the speed and park should be built in the motor/gear box.
Oct 17, 2013 | Ford Mustang Cars & Trucks
Looling for parts diagram for lionel westside shay engine
contact Lionel Parts & Services:
http://www.lionel.com/ContactUs/
Dec 05, 2012 | Toys
Put smoke fluid in the wrong place on Lionel polar express train, got all the controls wet on main engine
Remove the shell. Soak up as much as you can. Leave out to dry or use a hair dryer on low until controls are dry.
Dec 03, 2012 | Lionel The Polar Express Train Set
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Small bubles appearing under red paint. Local
your correct, if you wait about a year you will notice rust in those spots
Jan 28, 2010 | 2005 Nissan Titan
Toys Logo
228 people viewed this question
Top Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
