Question about Lexmark X4270 All-In-One InkJet Printer
Paper jam When I try to print, the paper feed pulls to the right and jams the paper and the printer ask to add paper and press select. I pull the jamed paper out and press select and it does it all over again.
  • 1 more comment
  • Rebecca Marshall Apr 25, 2008
    Thank you, but I checked and no paper is in the printer.
    I tried to move the roller over to the middle but it didn't move. Can I push it hard and not break it? Thank you for your help but I wasn't able to move it.
    Master:
  • 788 Answers
Either there is something stuck in the paper path on the left side. Or one of the pickup rollers aren't turning, there usually is two pickup rollers in this type of printer. They are used to straighten out the paper during feeding. There is also most likely two sensor used to determine if the paper is straight. If there is paper stuck in one of the sensor the printer might not turn it's coresponding roller. Or the paper just might be getting stuck on an obstruction. It is sometimes difficult to see if anything is stuck in the paper path. I would suggest opening all the doors on the printer and use a flash light and can of compressed air to try to dislodge anything that may be in there. It might not even be a peice of paper, I've seen thumb tacks, paper clips, even toy cars stuck inside printers.
There is also sometimes a clear peice of mylar film that is used to help guide the paper and to avoid grabbing multiple sheets. I've seen that plastic get pulled out after a jam then causing more jams afterwards. Look down inside the paper tray and look at the rollers, if you see a clear plasting strip sticking up you may need to push it down.
If all else fails, for the price of all-in-one printers these days, and if I'm correct your X4270 cost you less than $100, I would consider replacing the printer. I would consider something from Epson, Canon, or HP, as Lexmark has not always been known for exceptional reliability in it's low cost printers.
Posted on Apr 25, 2008
  • Dean Joly
    Dean Joly Apr 27, 2008
    If you are certain that there is nothing stuck in the printer than your only other solution is to replace the printer as no one will repair it for you, it isn't worth it.
  • 563 Answers
Hi There
Have you tried the Lexmark Troubleshooting Guide in your User's Manual ?
Click HERE to view it online.
Good luck and thanks for using Fixya !
  • Lexmark Master
  • 13,433 Answers
I had a similiar issue with my printer the paper is pussed too thightly in the printer, make sure the paper have atleast a little room in the paper feed dont push them in there.
If reseting the device hasnt work and also try with only one paper in the feed see how it goes.
if whatever you try the paper gets jammed still contact lexmark or your dealer for repairs.
    Genius:
  • 2,785 Answers
Dear jamie
Your paper sensor is dis-placed from the original position,you have to open it and see for any breakage, it is better that you ask some professional to open your printer if you are not very comfortable with opening printers
  • 871 Answers
Please try to re- adjust the roller which is responsible for the paper feeding,
if the roller is dis-aligned, what you are experiencing right now is the effect.
Posted on Apr 21, 2008
  • earl norman llanera
    earl norman llanera Apr 21, 2008
    with regards to sweet_rascal,
    if my solution doesnt work, please try sweet rascals solution. hi guys...
  • 2,326 Answers
It might still have some paper left inside the loading mechanism.
I would suggest to open it and inspect all the moving parts as well for a worn out condition.
    Guru:
  • 1,894 Answers
It is needing a hard reset sir.
nothing big
  • dewan nafees ahmed Apr 21, 2008
    hi early..
    how u doing... am fine..
    have a great day..
    \thank you
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
When trying to print paper pulls to the right and jams
try feeding the paper first, mine pulls to the right also, but if I hold it when is jerks, sometimes it will not jam
Dec 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
