After about one minute of operation it detects overheating and shuts down. The main cooling fan immediately comes on to cool it down. All filters are clean
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Startup process is all normal. Countdown then the image is on the screen. In less than 60 seconds the green led goes out leaving only the Red lit. Cooling fans crank up to cool it down and then it starts back over. I am NOT getting an overheat indicator lamp coming on. All fans appear to be working.
