I have found the manual for you. Go here and enter the model number (you don't need the serial) It will give you a pdf of the manual. I hope it helps! Please rate me! :) http://mieleprofessional.ca/ca/prof/products/manuals.aspx
Hi
First
check if the drain hose is not clogged and try to clean it as it can be that
the hose is clogged and the water is not draining properly. After that check if
the drain pump filter is fine and not clogged, try to clean that as well. After
this check the metal filter, impeller cover and the air gap unit. After checking this you can
reset the error as follows: turn the rotary selector switch to "Stop/End" or
press the "Start/Stop" switch for approx. 5 secs. Then switch the
appliance off and then back on again. Hope
this helps...please post back for further assistance.
Daniel
