Question about Maytag 24 in. MDB9750AW Dishwasher
I have a maytag mdb9750aw dishwasher and it is
Making a plastic ticking,grinding, crunching sound. It still works, but I fear not for long.
  • Maytag Master
  • 3,361 Answers
Http://www.servicematters.com/maytag_library/docs/16021814.pdf
This service technicians manual covers your unit.
Posted on Jul 17, 2010
Hobart sr24 dishwasher making a grinding metal on metal sound
Pump bearings, staff dropped a teaspoon down the inlet to the pump. You need a service engineer. Don't run it.
I have been in the hospitality for 45 years and seen it all. Our drain mechanism broke a month back and it was full of cocktail sticks. We just got a brand new machine.
May 18, 2016 | Hobart SR24-H Built-in Dishwasher
Tip
Maytag recalls dishwasher/fires feared from heating element
Maytag is recalling dishwashers for fire hazards including Maytag, Amana, Jenn-Air, Admiral, Magic Chef, Performa by Maytag and Crosley brand dishwashers with plastic tubs and certain serial numbers.
Check these serial numbers to see if you have the dishwasher in question.
Call 1-800-544-5513 if you think you have one.
on Jun 04, 2010 | Dishwashers
Replace grinder blade
As long as you didn't damage it, it should be ok.
May 22, 2012 | Maytag 24 in. MDB9750AW Dishwasher
No lights are coming on seems to have no power and i have checked the breaker
I know this sounds silly but, check the level of the dishwasher, if the door does not shut exactly right with it level my lights wont work, I can move it slightly to the side and forward (leveling it up) and bingo I have power and lights.
Dom
Mar 18, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Loud noise
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Machine won't run - door latch fails
remove all the screws on inside of the door .pull apart the inner plastic part of the door from outside panel and look at the door latch on the top of the door.probably it will be broken or door sws are bad.
Aug 18, 2009 | Maytag MDB9750AWS Built-in Dishwasher
Maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Kitchenaid dishwasher makes a crunching sound during rinse cycle
Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
Maytag 24 in. MDB9750AW Dishwasher Logo
133 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
