Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Brush motor quit. table cloth was pulled up in brush. nothing is broken motor turns free. Is there a overload fuse?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Have you checked the belt drive on the brush roller to the motor
Posted on Jul 28, 2010
The brush quit turning
Sounds like 2 separate motors. remove the beater bar and see f that motor turns without any load. Of not time for a new beater bar motor.
Dec 22, 2014 | Vacuums
Brushes not turning
Unplug it from the power source. Then remove the cover and see if the belt is broken or derailed from the motor.
Sep 02, 2014 | Vacuums
Why doesn't it suck
Hi Julie,
The drive belt that attaches to the floor brush and impeller motor has stretched out or has become broken. Turn upside down, remove screws. Carefully support and pry apart gently. Take a picture before pulling it apart to clean it by hand. Then replace with backup belt located somewhere on the machine or in the filter bag pocket. You will be back in business in no time.
Oh yes, there is also an electrical connection when snapping the wand to the floor vacuum. Remove and reset. Check for overload switch if it is doing nothing. There is a reset. Fare. Well.
Jul 05, 2014 | Miele S318 Bagged Canister Vacuum
The beater motor will not turn. Is there a fuse? I've tried the reset, but this still doen't work. My wife smelled a burning smell and quit using.
Sounds like you need a new belt.Turn it upside down and locate the screws on the bottom.Remove those screws,and then the plate they hold on(if there are no screws then the plate will be held by clips just pull it off,carefully.The brush now may be lifted out,but before you do.The belt fits around the brush.Find which side,if the belt is broken and still in the vacuum,it should still be on the side it came from.If the belt is not still in the vacuum,there is a groove in the brush about one inch wide.That is where the belt fits.The other end of the belt fits on a small wheel about 4-5 inches back from the brush.There may be a small plate over the belt and wheel if so just remove it and you will see what I am talking about.
May 17, 2011 | Eureka Capture Upright Vacuum Vacuum
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Power cuts maybe after 10 mins use, then after switching off for an hour or so, it works again! repeat.
I would think that it is probably a motor going bad and tripping the overload switch. After the overload resets, it will run again. Is there a chance that the motor is still under warranty? Some vacuum maker warranty the motor for longer than the rest of the vacuum (Dirt Devil is 6 years on the motor) so hopefully they will fix it for free. One other thing, should be obvious, but I'll ask anyway -- the brush is turning properly and the vacuum has suction when it is working, right? if something is jammed that could overload the motor as well.
Nov 19, 2009 | Vacuums
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
Brush motor quit
The beater bar belt is broken.
Nov 18, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover carpet cleaner f7425-900
the brushes are run on a vacuum the switch may no be opening
Nov 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
240 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
