Question about Kenmore 22422 Top Load Washer
I have a Kenmore 90 series heavy duty washer that is leaking water all over my floor enough to soak up a couple of towels. What can this be and how do I fix? thank you.
  • Kenmore Master
  • 2,699 Answers
Could have a cracked water pump or the pipe that the drain line drains into is backing up.one other thing it could be is bad tub seals,the water will leak from the bottom middle of the tub but most likely it will be the pump,this is an easy fix,pop off the two clamps that hold the pump on and with a pair of plyers remove the two clamps on the hoses,make sure you put down a couple of bath towels to catch water that's still in the hoses,let me know how you make out,next time send model number,one of the most common pumps for your machine is 3363394 but check it with the part number on the old pump and give the parts store the correct model number.good luck
Posted on Jul 18, 2010
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Feb 25, 2009 | GE WHRE5260E Top Load Washer
Kenmore 22422 Top Load Washer Logo
233 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
