Question about Sansui Audio Players & Recorders
  • 58 Answers
SOURCE: Receiver will not output any sound
1st Try to push (ON) A/B speaker Selector terminal. 2nd try to reset the speaker relay by put the volume on 15% and short-cicuit the speaker terminal for just 1 sec. with the power ON. Good luck
Posted on Aug 11, 2007
  • 4 Answers
SOURCE: nad 214 amp
problem is- intermittent speaker relay. You can cleaned contacts or better upgrade relay to better one (sealed)  Dariusz
Posted on Feb 13, 2008
  • 518 Answers
SOURCE: Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Posted on Mar 07, 2008
SOURCE: Pioneer SX-203
Try taking the receiver apart and checking the fuses.
Posted on Mar 23, 2008
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Posted on Jan 12, 2009
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
Pioneer sx315 receiver shut off after being cranked up for a while and wont turn back on checked fuse its good. power button seems to work clicks when turned on and off
If the power to the outlet is still good, then I would suspect the power amp IC or output transistors are shorted, keeping the power from coming on. It's also possible that one or more of your speakers are bad feeding back to the receivers output connectors, especially if you were running speakers with a different power rating or impedance that your set is designed for. Hope this helps.
Jul 10, 2011 | Pioneer SX-315
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
Speakers not playing correct on a Pioneer SX-550
It could be the speaker output or the amp input. If you have a headphone socket on the amp try headphones and hear if it's the same problem.
If it's the amp's power output then this can be repaired. It's a case of unsoldering the blown transistor or integrated amp chip and soldering in a new one. It's not hard but you need to find someone competent.
Apr 28, 2017 | Pioneer Audio Players & Recorders
No sound from speakers?
This is likely to be th output relay having corroded contacts. The headphone output is taken directly from the sepaker output but fed through resistors. The output relay has failed.
Mar 09, 2009 | Pioneer Audio Players & Recorders
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
105 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
