Question about Sharp XR-30X Projector
Is there a driver? I have a ghost image. - Sharp XR-30X Projector
  • Sharp Master
  • 6,993 Answers
what type of driver are you referring to, do you mean software driver? If you mean software driver, then you will have to contact the manufacturer of this product because the software drivers is not available anywhere online.
If your question is otherwise, please let me know.
Take care.
Posted on Jul 17, 2010
Ghost image on a hp CM1415
Two reasons for ghost image
1. Toner cartridge faulty.
There is a part in toner cartridge called Drum cleaner (also called as tractor blade), if this part not clean the drum surface properly ghost image will form on drum & it will transfers on paper..
2. Fuser assm faulty.
There is a part in fuser assembly called Teflon sleeve. If toner particles deposited on teflon sleeve you may get ghost image..
May 08, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Ghost image ricoh 3245c
No can do, if you are referring Norton Ghost. Ghost it only for OS on computers. Printers have chips with instructions.
Here are the drivers in case you need them.
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c35_45/c35_45en.htm
Oct 25, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
I have prescott 533 mother board also having XP SP3. but i cant installd sound driver. pl send the audio driver download link.
try http://rapidlibrary.com/index.php?q=prescott+533+driver+download
make a ghost image using norton ghost before installing any sound driver. if you installed already any driver, reinstall your windows. the sound driver keeps some files that are very difficult to delete.
if the drivers from the links are not got, reply and i will search different ones
Oct 25, 2009 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
DELL DL-380 G5 "could not allocate page table memory" GSS 2.5
First of all, Dl380 is an hP product.
Secondly your ghost version seems a bit old as ghost 14 is the latest version. Having said that the problem could be at two ends.
1. At the ghost side where your version doesnot contain NIC drivers for PXE boot and HDD drivers for imaging. To fix this you can try manually adding the drivers to the network boot or floppy boot diskette.
You can get the drivers from HP website or the PSP CD that came with the server.
Alternatively you can upgrade to RDP instead of GHOST, RDP is Symantec's offering sold by HP for imaging it's servers.
2. There's some problem with your NIC settings or card if you are trying to PXE boot.
If you are using a floppy drive/ usb HDD, check from BIOS if it is detected.
Jun 25, 2009 | HP Compaq ProLiant DL380 G4 Server
I wish to ghost my pc
two software I've used previously are Norton Ghost and Drive Image but I don't believe you can image to an external drive. you might want to research on a newer version of norton ghost. they might have driver for external drive. Both of these software can be purchase online and download it. Hope this helps..
Good luck!!
Joe
Mar 25, 2009 | HP Computers & Internet
Why restore ghost image
You will need to restate your problem in better english.
Jan 07, 2008 | Symantec Client Migration 3.0 Add-On to...
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Sharp XR-30X Projector Logo
472 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
